Why does my car cut off when im slowing down?
Old Jan 11, 2006 | 06:43 PM
93hondaprelude's Avatar
Default Why does my car cut off when im slowing down?
i have a 93 prelude and after it gets warmed up i try to slow down and it mainly does it when i put it on neutral or hold the clutch in the RPM's will go all the way down below 0 and jump back up then go all the way back down below 0 and most of the time cut off while im either slowing down or stopped. sometimes it will do it while im tryin to turn also. Me and someone else think it might be the idler is set too low or one of my sensors have gone bad and need to be replaced. if anyone has any help or ideas what it might be please let me know.
Old Jan 11, 2006 | 11:12 PM
allmtrdc4's Avatar
Default Re: Why does my car cut off when im slowing down? (93hondaprelude)
bump would like to know my self
Old Jan 11, 2006 | 11:23 PM
Tad's Avatar
Tad
Default Re: Why does my car cut off when im slowing down? (allmtrdc4)
hmm,
first things that come to my mind,
are maybe ur just not getting enuf fuel to hold ur idle?
hows ur fuelpressure?
could be a bad/clogged eacv or fast idle valve?
My car kinda does that, but to a lesser extent,
the higher I raise my idle the less it does it.. but then my idle is higher of course..
I'd say try and find the problem before u do this, as its a temporary bandaid, but just unscrew ur idle screw on ur throttlebody somewhat to raise ur idle, so u can get around without ur **** dying.
Old Jan 12, 2006 | 03:28 AM
Default Re: Why does my car cut off when im slowing down? (Tad)
aight thanks man ima try that first until i can find the time to take it somewhere and get it fixed if i figure it out ill post it up here what they did.
Tip14
May 7, 2007 06:09 AM
eric416
Aug 5, 2005 09:50 AM
Yield
Sep 28, 2004 07:16 PM
boostin4drcivic
Feb 1, 2004 09:15 PM
VtecInteg95
Dec 15, 2002 06:29 PM
