White spark plug on cyl 1??
Old Aug 31, 2003 | 07:23 AM
evo's Avatar
evo
New User
Default White spark plug at cyl 1??
Took the spark plugs out today, I found them all brown except the cyl 1 plug appear white.
It may running lean or overheat but what cause the problem, my friend told me it may be the injectors clogged.
any suggestion. thanks
Old Aug 31, 2003 | 07:56 AM
evo's Avatar
evo
New User
Default Re: White spark plug at cyl 1?? (evo)
ttt
Old Aug 31, 2003 | 08:31 AM
PAPOBMX's Avatar
your friend is not lieying you should change the injector or clean it
Old Sep 5, 2003 | 03:21 AM
mattb16a1civic's Avatar
yes white is generalyl lean, id also suggest cleanign the injector, you should talk to someone at a dealership about injector cleaning nto the stuff u buy in a bottle but stuff they actually feed into your fuel rail, its pimp **** used it at UTI. we just used gm cleaner for everything even in the imports, called honda and they said it was fine.
Old Sep 5, 2003 | 07:57 AM
GS-Rcivic's Avatar
i have the same probem but i melted 2 plugs while sprayin. Where can i go to get them rebuilt, machine shops?
axionm1k
Jul 17, 2008 05:02 PM
USDM-EK4*
Oct 21, 2007 06:54 PM
USDM-EK4*
Oct 21, 2007 06:35 PM
92CivicSiR2
Sep 22, 2004 01:30 PM
NZcrx88
Aug 2, 2002 02:03 PM
