white smoke from freshly rebuilt LS, HELP!
Old Jul 6, 2010 | 07:44 PM
RPMvulocity's Avatar
Default white smoke from freshly rebuilt LS, HELP!
engine:b18b turbo but has NEVER seen boost
Like the title states, i have blueish white smoke coming from the exhaust(indicate oil burning) and a little bit from the valve cover. The rebuild consist of new gaskets(head, intake, exhaust, oil pan and etc), new OE rings, new LS pistons on stock rods, and ACL rod bearings, OE main bearings.
I have done a leakdown test and got a 0% leak reading at 100psi on ALL four cylinders. It's a new turbo so i know it's not seals from the turbo. the only thing i could possibly be is valve seals? that's the only thing that makes sense to me that oil could be seeping through to burn. i was reading around and people were saying that it was ringlands but these are BRAND new pistons and rings and havent got more then 1mile on them. I clocked and triple the piston ring gap and piston to wall clearance and everything checked out when i had it apart. I am jus stumped!!
oh and i put a quart of Lucas oil in it(jus for kicks) and the smoke went away for about 20mins then came back a little less then before so im thinking valve seals...
anyone agree or can tell me where to check!! thank you for any answer
Old Jul 6, 2010 | 10:55 PM
b18efSI's Avatar
Default Re: white smoke from freshly rebuilt LS, HELP!
running lean??
Old Jul 6, 2010 | 11:55 PM
itslogz's Avatar
You did all that and didnt replace the valve seals?
Thats probably going to be your answer.
Old Jul 7, 2010 | 04:30 AM
yeah that's exactly what i was thinking to myself...did all that **** and i didnt even replace the valve seals, that's what im leaning towards
Old Jul 7, 2010 | 06:41 AM
spoolin99si's Avatar
What kind of turbo do you have on there?
In the event you DO have an eBay, I have seen some smoke right out of the box..
Old Jul 7, 2010 | 08:54 AM
no it's a garrett t3/to4e 50trim turbo...new straight from the shop
Old Jul 7, 2010 | 11:10 AM
blackeg's Avatar
hey not for nothing here, but they all smoke and smell like **** on brand new startup. sometimes for me they clear up after 5 minutes, sometimes ive had them smoke for a week. with a good tune, go put some load on that motor and seat everything nicely. id drain that lucas out though.
Old Jul 11, 2010 | 04:51 PM
thank you, i jus re-did the timing since i noticed i was off a half degree and the belt had a little more play then it suppose to, i turned it back on and the smoke was gone and drives perfect. not sure if being off half of degree had to do with the smoke, but it's gone now. and yes now im driving it and putting some miles on the motor.
Old Jul 12, 2010 | 02:25 PM
dragdatzu's Avatar
yeah man most newly rebuilt engines moske a lil bit till they break in and everything seats...if you didnt replace the valve sealy you probly should have and if theyre not leakin you got lucky for now....i some how forgot to replace mine last time i rebuilt mine and i wasnt so fortunate.....
codyweiss97
Mar 8, 2014 11:04 AM
Joeski99Si
Aug 2, 2009 11:25 AM
91_db1
Nov 10, 2008 09:46 PM
G-Phi
May 17, 2006 07:38 PM
