where are all the auto tech?
Old Jul 13, 2006 | 01:17 AM
fizzerlee's Avatar
Default where are all the auto tech?
my car is having break problems. i just replaced the master cylider and now the pressure is alot better. but i think its to tight. it feels like the breaks are still on when i release them. another thing is that they got really hot, to the point where i felt heat on the rims. is that normal? after a break change? i bleed the system and all that.
i described it to the best of my knowledge. but if you guys have question please ask.
thanks for your help.
Old Jul 13, 2006 | 07:25 AM
Crazydave's Avatar
Default Re: where are all the auto tech? (fizzerlee)
they shouldn't feel like the brakes are still on when you release them, did you lube the caliper slides (pins) when you fixed them.
as for the heat.... thats how brakes work, they turn kinetic energy into heat
if they are smelling funny, then you might have the problem described above
Old Jul 13, 2006 | 08:51 AM
slowassgsxr750's Avatar
check your break booster
Old Jul 13, 2006 | 12:17 PM
Scott_Tucker's Avatar
You may have a caliper(s) that is sticking and causing the brakes to stay on after you apply the brakes. This would explain why the it feels like the brakes are still on after you hit the pedal and also why you are getting so much heat into them (like you said the wheel gets hot).
Old Jul 13, 2006 | 05:13 PM
fizzerlee's Avatar
Default Re: where are all the auto tech? (Scott_Tucker)
would that explain why the break ( where i step on) is also tight???
Old Jul 13, 2006 | 05:53 PM
Yes, it could.
Old Jul 13, 2006 | 06:16 PM
DATZ WEAKSAUCE's Avatar
so what should i do? its sticking to the front and i never changed them. bubt the ways its going i think im going to have to soon
Old Jul 13, 2006 | 07:08 PM
onepoint6i's Avatar
Default Re: where are all the auto tech? (DATZ WEAKSAUCE)
lift the car up and turn the wheels by hand, if theres too much drag on either wheel to where it wont spin... then you have a problem...
make sure your lines arent twisted, and make sure your pins are well lubed...
Old Jul 14, 2006 | 08:21 AM
thesmogman's Avatar
Also check the brake pedal adjuster it might be to long and pressing on the M/C all the time.
You did leave the gasket on the M/C between the M/C and the booster.
And are your brakelights on?
Old Jul 14, 2006 | 10:25 AM
fizzerlee's Avatar
Default Re: where are all the auto tech? (thesmogman)
the brakes only stick when im going fast 45+ so usually on the freeway. someone said it might be the brake booster. i dont think its the pads or calipers. unless getting brake fliud on them makes a difference. and making them stick?
RichardDixon
Suspension & Brakes
Feb 13, 2018 07:14 PM
_BEN_
Jul 4, 2004 10:51 AM
zdimka
May 31, 2004 01:09 PM
evilblueflames
Jan 31, 2003 08:04 PM
from_zer0
Apr 22, 2002 10:40 AM
