built gsr bogging out at vtec
Old Jul 12, 2006 | 09:05 PM
hialeahzbg's Avatar
Default built gsr bogging out at vtec
my boy just got his gsr head built with buddy club valvetrain and skunk2 cams...hes got a 96 dx coupe and we wired his vtec...now the car runs fine but when around 5,900 rpms when vtec engages it bogs out and studders and then when it gets to like 6,500rpms it starts to pull...hes mad and wants to sell it...please help me out so he doesnt do a bad decision...
Old Jul 12, 2006 | 10:38 PM
qfast817's Avatar
Default Re: built gsr bogging out at vtec (hialeahzbg)
well is it tuned? and di he do valve lash
Old Jul 12, 2006 | 10:46 PM
hialeahzbg's Avatar
not tuned....i dunno what a valve lash is...
Old Jul 13, 2006 | 01:35 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (hialeahzbg)
Sounds like its leaning out. Check the fuel delivery.
Old Jul 13, 2006 | 05:30 AM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg &raquo;</TD></TR><TR><TD CLASS="quote">not tuned....i dunno what a valve lash is...</TD></TR></TABLE>
Sounds like you and you "boy" need to have the car tuned and adjusted by a professional, you dont njust drop in cams and get power. You cando serious damage to the engine by running lean and having the valve lash set to tight. If you want to know what valve lash is, chec the card that came with your cams, that will give you the spec's and do a simple search on here
Old Jul 13, 2006 | 08:14 AM
hialeahzbg's Avatar
we didnt install it we took it to a machineshop to do...but they cant figure it out...when we cover a vaccum in the manifold it idles like at 200 rpms and when we leave it open it idles like at 1100 rpms....will a tune fix all this mess...
Old Jul 13, 2006 | 05:33 PM
hialeahzbg's Avatar
any other ideas?
Old Jul 13, 2006 | 05:50 PM
qfast817's Avatar
try tuning, or put the stock cams in
Old Jul 13, 2006 | 07:10 PM
onepoint6i's Avatar
Default Re: (qfast817)
definetly a tuneing problem...
Old Jul 13, 2006 | 07:42 PM
mmuller's Avatar
Mad Scientist
what ecu are you using?
so the car idles at 200 rpms? reset the idle to 750_+50 dont leave any vaccum hoses unplugged.
Old Jul 13, 2006 | 10:49 PM
hialeahzbg's Avatar
hes used a jumper and chipped p28...ok we covered a vaccumm in the back of the manifold thats the closest to the brake booster...we put a small hose with a screw in it to block the air...it idles at about 200 or 300rpms...we unplug that vaccum and he idles like at 1100...it has a 00 gsr motor and a 96 dx harness with the vtec ran correctly...car ran fine when the head was stock...now the cams and valvetrain idles wierd and bogs out when vtec engages but then runs fine after like 6200 roms...
Old Jul 13, 2006 | 11:26 PM
mtber's Avatar
You may simply need to have the car tuned
Old Jul 14, 2006 | 06:35 AM
hialeahzbg's Avatar
will that fix the idle?
Old Jul 14, 2006 | 07:02 AM
onepoint6i's Avatar
yup...
Old Jul 14, 2006 | 11:49 AM
hialeahzbg's Avatar
thanks playaz! my friend really appreciates this...
Ryanwill86
Feb 14, 2009 11:15 AM
Shift_Fast
Feb 19, 2005 11:24 AM
sleeperb16a
Jun 20, 2004 08:54 PM
LSTEG96
Apr 15, 2004 07:48 PM
