when they say it has THIS duration and THAT lift....at valve or cam?
Old 09-19-2004, 11:37 AM
z6
z6's Avatar
Default when they say it has THIS duration and THAT lift....at valve or cam?
when i look up the stock specs of the d16z6 I am confused as to if those specs are measured at the valve or at the cam? If somebody knows what the d16z6 rocker arm ratio is PLEASE POST IT. and are the advertized cam specs at the valve or cam?
Old 09-19-2004, 12:47 PM
GeeReg's Avatar
Default Re: when they say it has THIS duration and THAT lift....at valve or cam? (z6)
Advertised specs are at the cam. As for the rocker ratio, I can't help you.
Old 09-19-2004, 02:09 PM
Kendall's Avatar
I remember seeing a thread that had all of the rocker ratios sometime back, but I haven't been able to find it.
Old 09-19-2004, 07:32 PM
B18 CYA's Avatar
Default Re: (Kendall)
nobody knows??
Dark91zc
01-06-2006 03:27 PM
B18C5-EH2
11-14-2005 06:07 PM
CrXr89Si
02-17-2004 11:14 PM
Aron Parsons
02-04-2002 06:38 PM
Quick Reply: when they say it has THIS duration and THAT lift....at valve or cam?
