When do you need to tune?
Old Mar 29, 2008 | 12:31 PM
bigsyke's Avatar
Default When do you need to tune?
JW when it would benifit in power and reliablility to tune the ECU? right now on my EJ8/D16y8 I have;
2.5" SRI aem filter
2.25" DNX midpipe, magnaflow muffler
DC 4-2-1 header
Looped coolant lines
OEM cat.
I have OBD2 right now, and I know it will add up to 21% more fuel, but will OBD1 do the same? I see so many suggestions to convert to OBD1, but only figured if your heavily built. Cant OBD2 handle with just bolt ons? I have no emissions where I live either.
Old Mar 29, 2008 | 01:12 PM
KENetics1's Avatar
Default Re: When do you need to tune? (bigsyke)
based on your mods i don't find it necessary to tune with just your basic bolt-ons. tuning is really only necessary when you do internal engine mods(ie cams, pistons) or forced induction. You can if you want but would net you minimal hp gains.
Old Mar 29, 2008 | 01:47 PM
bigsyke's Avatar
Thats what I thought, I was thinking it might be better to tune for reliability, but as long as the o2 is functional, i should be fine
Old Mar 29, 2008 | 02:01 PM
IanB's Avatar
OBD2 uses the O2 sensor output to adjust fuel when it is idling, cruising, etc. When you go wide open throttle it runs off preset maps in the ecu, and uses no outside data from the O2 sensor, that's where the tuning would come in (open vs. closed loop). The ecu is not able to analyze and adjust for rich or lean conditions at wide open throttle, tuning would make those preset maps match your engine and what it needs. With more mods, bigger changes to these maps would be necessary, but that's not to say you won't see benefits tuning what you have now.
Old Mar 29, 2008 | 02:11 PM
bigsyke's Avatar
not to sound lame. but mainly its my DD, ill take it around the track once a year, but I dont think IM ever at WOT. lame yes- but im a bit paranoid.
lostwun1
May 2, 2018 08:26 PM
court76wi
11
Oct 12, 2009 08:29 AM
Nick97hatch
Oct 10, 2004 10:56 AM
98 blacksh
Feb 6, 2004 01:00 PM
paulyman
Aug 26, 2002 04:40 PM
