when do you need a MSD ignition and coil?
Old Nov 18, 2001 | 06:32 PM
OneThirtyEight's Avatar
Default when do you need a MSD ignition and coil?
I hear all the BS, that MSD iginitions dont do ****, ect. when do they actually help a great deal? I have the following
b18b LS motor
ITR pistons
Port/polish and valve job
venom manifold
milled head
crower ti retainers
crower dual valve springs
big bore TB
greddy header
DC exhaust
AEM CAI
fluidline radiator
280cc injectors
AEM fuel rail
ACT clutch
IM about to get some 6403 cams, and wondering if an ignition upgrade is in order?
Old Nov 18, 2001 | 08:11 PM
Jared's Avatar
Default Re: when do you need a MSD ignition and coil? (97blackteg)
I don't see needing an upgraded ignition until you go big with the nitrous or boost.
Old Nov 18, 2001 | 11:05 PM
JR_sohc's Avatar
Default Re: when do you need a MSD ignition and coil? (Jared)
im runnin about 6lb boost with a s/c. i kno i need to get my motor tuned. with wha im running, would it seem that im in need of goin with some ingnition work.
Old Nov 19, 2001 | 04:37 AM
ImportechPerformance's Avatar
Default Re: when do you need a MSD ignition and coil? (JR_sohc)
I would say that "YeS" JARED JR_sohc you would benifit from ignition work cuz you dramaticly upped the HP with boosting and since you will be tunning it might as well get the ignition tuned in with the rest. to get everything insnyc. But as far as giving you more HP i doubt it probably just run a bit smoother. As for the guy at the top i wouldnt do it. spend your money somewhere else.
Old Nov 19, 2001 | 07:14 AM
rainforest's Avatar
Default Re: when do you need a MSD ignition and coil? (MrPimpon)
well how much is your head milled? in high compression motors like mine(12.1) i use a 6a and a blaster 3 coil it helps with detonation. so i run it just to be safe. But stock honda ignition is great lots of highly modded N/A and F/I motors sre running stock ignition.
Old Nov 19, 2001 | 09:18 AM
Default Re: when do you need a MSD ignition and coil? (rainforest)
ok, so maybe just get a coil.
thanks.
Old Nov 19, 2001 | 06:05 PM
Max_ED9's Avatar
hey, whats the highest you can rev to on that ls with titanium rataniers and vlavle springs?????
madhatter2199
Jul 12, 2005 08:29 PM
lupin5
May 23, 2005 06:36 PM
theinfamouskonrad
Mar 29, 2005 08:27 AM
shermanyang
Sep 15, 2004 05:49 PM
Bspec18
Jun 30, 2003 12:55 PM
