Wheel & Tire setup question on EK civic.
Old Apr 19, 2004 | 11:05 AM
Quick4's Avatar
Default Wheel & Tire setup question on EK civic.
Is anyone running 17x7.5 wheels with 205/40 17 tires? If so, what offset are you running, I'm thinking of 43. Do you have clearance problems? I really want to go with 17s over 16s due to the limited tire choices with 16 inch wheels.
Old Apr 19, 2004 | 03:58 PM
Adam.'s Avatar
Default Re: Wheel & Tire setup question on EK civic. (Quick4)
Personally, if I was gettinga 17x7.5 I'm going with at least 210 width if not 225...
Old Apr 22, 2004 | 02:10 PM
Quick4's Avatar
Default Re: Wheel & Tire setup question on EK civic. (DarkKnight[DMD])
Well, I couln't find a 215 in the tire I want, and I don't think any tire company makes 210's. but 225 is too wide for the suspension of the civic. Tire rack suggests the 205/40 for that rim width, I just don't want it to look funny or rub.
Old Apr 22, 2004 | 02:23 PM
doucmehu's Avatar
I wouldn't do it based on looks. It ends up looking like the tire is barely holding its seal, stretched across.
Old Apr 22, 2004 | 02:28 PM
Mighty's Avatar
I had problem with a 205mm tire on a 16x7 rim. The rim was a tiny bit wider than the tire. This allowed the tire to drop into a pot hole and the rim caught on the edge. This bent the rim. So I went down to a 15x6.5 rim with 205mm tires to prevent this problem. I know a lot of people run 205s on a 16x7 but for me it was a problem.
jordanz
Oct 19, 2010 05:46 AM
^AnDre^
May 1, 2007 06:39 AM
BlazinITR
Feb 10, 2003 06:55 PM
Mr. Vapor
Jul 1, 2002 11:23 AM
