TPS Reading problems and VAFC (turbo)
Old Apr 22, 2004 | 09:57 AM
Trac226's Avatar
Default TPS Reading problems and VAFC (turbo)
Hi Guys,
Just finished putting my block back in and I came across the tps signal that's bugging me. When the ignition is ON, I get the normal voltage readings from the TPS at closed and WOT positions. But, once I start the engine, the VAFC doesn't read the voltage anymore, just sits at 0%
It's been fine before I swapped out my block. Could I be missing some ground wire, or could my throttle cable be way off??
this sucks! thanks
Trac
Old Apr 22, 2004 | 10:12 AM
TIRENECK's Avatar
Default Re: TPS Reading problems and VAFC (Trac226)
is the vafc on close throttle? read the manual cause u can control the tps with the vafc.
Old Apr 22, 2004 | 02:29 PM
Trac226's Avatar
Default Re: TPS Reading problems and VAFC (TIRENECK)
My battery voltage just picked up to normal and my idle seems a lot better. But I am still having problems reading the TPS when the engine is on.
TeknikDC2
Feb 23, 2005 11:17 AM
evo
Apr 6, 2003 09:32 AM
redlinegsr
Dec 6, 2002 11:32 AM
Art Vandeleigh
Oct 26, 2002 09:14 PM
