wheel bearing noise???
Old Aug 13, 2003 | 02:31 PM
bigseth2468's Avatar
Default wheel bearing noise???
well i drive a 96 dx hatch and lowered it a couple of months ago (maxspeed coilovers nothing special) but i've had a strange noise coming from the passenger side rear wheel. a friend of mine said it could possibly be the wheel bearing going bad. i checked to see if anything was rubbing and nothing seemed to be. i'm only getting the sound from this one wheel. anyone know what this is?
Old Aug 13, 2003 | 03:33 PM
tilt's Avatar
Default Re: wheel bearing noise??? (bigseth2468)
it's either going to be the wheel bearing or a bent wheel or irregular tire wear/balancing problem.
lift wheel off ground and try to move it. any play means the bearing is bad. to see if the tire/wheel is the culprit just rotate the wheels and see if it still happens.
Old Aug 14, 2003 | 11:40 AM
obsidianG35's Avatar
I have the same problem, I tried balancing, first it seem to help but i came back.. I'll try lifting it off the ground like you said.
Old Aug 15, 2003 | 07:23 PM
Default Re: (r4integra)
thanks guys anyone else have any suggestions?
Phil_46
Jun 11, 2013 09:16 PM
Jamezvtec
Honda Civic (2001 - 2005)
Jun 11, 2009 04:43 PM
94eh2
Feb 15, 2007 02:05 PM
Mr_Moos
Jul 10, 2006 02:50 PM
Brewer
Jan 20, 2006 11:48 PM
