Whats that sensor on the back of a JDM B16a1?? Please Help!!!
Does anyone know what that sensor is that is on the back of a JDM B16a1 Block (OBD-0). It is the double wire sensor that has two independent plugs for it on the same sensor and has the black rubber cover over it??
I am planning on swapping out my b16a1 bottom end for a b18c1 and I know that this sensor only comes on the pre-obd engines, I am just wondering if I am going to be shooting a CEL on my PR3?? What can be done about that??
Thanks guys,
Later
Thanks guys,
Later
why would i not be serious?
that sensor will be the least of your worries... what are you using ATM for your radiatior fan switch?
t..
t..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tinkerbell »</TD></TR><TR><TD CLASS="quote">radiator fan switch.</TD></TR></TABLE>
no the Mugen or Spoon one won't fit directly... you'll need to make an adapter, for 45$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 »</TD></TR><TR><TD CLASS="quote">
no the Mugen or Spoon one won't fit directly... you'll need to make an adapter, for 45$</TD></TR></TABLE>
wtf?
wtf?
Its not the fan switch. Its the oil pressure dummy light. Reads oil pressure and sends a signal to the oil like when pressure is below 10 psi at idle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDmDxTuRd »</TD></TR><TR><TD CLASS="quote">Its not the fan switch. Its the oil pressure dummy light. Reads oil pressure and sends a signal to the oil like when pressure is below 10 psi at idle.
below 10psi at any time
but yes its for the oil pressure light.
</TD></TR></TABLE>below 10psi at any time
bullsh*t
the oil pressure sensor does NOT have two independent plugs for it on the same sensor and has the black rubber cover over it
or is this a Honda from Mars?
get it together guys!
and Kamin, you should be ashamed...
</TD></TR></TABLE>bullsh*t
bullsh*t
and Kamin, you should be ashamed...</TD></TR></TABLE>
I wouldn't have stated it that aggressively... but I agree. That's the fan thermo switch. The oil pressure 'idiot light' has a one-wire sender. How do I know? I relocated my idiot light sensor when I installed an oil pressure gauge. I've also had to replace my fan thermo switch before, so I KNOW that that is what tink says it is.
bullsh*t
Thanks, I had the same question, but...
Now that I have made an LS/VTEC out of my B16a1 obd 0 and a 94 LS block, how do I eliminate this and activate the fan? Seperate switch, different wire from the car (91 Teg RS) or what?
Thanks Hank
Thanks Hank
