What's the problems?!
iat=intake air temperature #2 cylinder intake runner red/ylw and grn/wht or blk
iacv= idle air control valve, sensor on back of manifold blu and yel blk
Looks like an Integra dash, but if so, you don't have vtec based off the redline.
Shuts down on it's own over and over? How does it shut down more than once? And what is shutting down?
If you mean that the engine dies, or cuts out, or something similar, then try actually being descriptive.
And, as grumblemarc says, post up the CEL codes the car is throwing.
i dont think TunerN00b saw the video, he thought it was just a pic im guessing, hopefully
i think he means it falls on face not stops
what ecu? im thinking not enough fuel
code 7: throttle angel code
code 30: tcm signal
code 21: v-tec solenoid valve
code 22: vtec oil pressure switch
code 30: not sure what that is...
code: abs sensors, but I deleted abs. Will figure that out.
Don't see how any of this codes cause my car to shuts down (off) when I rev up the car on the freeway. Having hard time to start the car.
code 30: tcm signal
what were the onset of these codes? thats a bunch of codes for a all of a sudden thing
code 7 is tps
code 30 is auto code
try put power(battery volts) to the vtec solenoid and see if you hear it click
code 7 might cause it to shut off
what ecu?
code 7 is tps
what ecu?
code 30 - auto code: what does that means?
ECU is p28
[QUOTE=TunerN00b;47444766]Correct. Thought it was just pics.
Carry on. I'll shut up now.[/QUOTE
i have a loud clicking noise on the pasengers side of my 1991 honda accord and my ANTI-LOCK light stays on. i've had no luck finding out where it's coming from, because when ther car stops, the clicking stops. PLEASE HELP!!
prosumer81
Dec 30, 2007 08:51 AM
jaycapz
Sep 24, 2004 08:12 PM
