whats this plug
Old Apr 29, 2007 | 08:07 PM
KING PIN's Avatar
Default whats this plug
whats this plug on this b16 motor its going under the crank pulley [IMG][/IMG]
Old Apr 29, 2007 | 09:50 PM
MR_FIX_IT's Avatar
Default Re: whats this plug (KING PIN)
what OBD is it?
Old Apr 29, 2007 | 09:55 PM
havok hybrid's Avatar
Default Re: whats this plug (Purple_GS-R)
Only needed on obd2 ecu's. Its the crank flex sensor.
Old Apr 29, 2007 | 09:59 PM
KING PIN's Avatar
ok ill check to make sure but unless im using a obd2 ecu i dont need it right ?
Old Apr 30, 2007 | 01:25 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (KING PIN)
right, and even if you do you can bypass it at the ECU
Old Apr 30, 2007 | 06:26 AM
SickSi99's Avatar
Default Re: (HondaPartsHero)
crank fluctuation sensor or crank angle sensor.
Old Apr 30, 2007 | 07:03 AM
KING PIN's Avatar
thanks guys
blowbyu24
Jan 12, 2007 10:54 PM
TheOwnrOfTheEk9
Mar 7, 2006 06:10 PM
FOMULA91
Nov 17, 2005 10:33 PM
Buktheng
Dec 27, 2004 08:20 AM
