What's involved in swapping out a crank?
Old Feb 24, 2003 | 03:13 PM
fowler!'s Avatar
Default What's involved in swapping out a crank?
I don't need detailed instructions, basically I want to know what I should replace while I'm down there and what other stuff I may run into.
tia
Old Feb 24, 2003 | 03:14 PM
sgT's Avatar
sgT
Default Re: What's involved in swapping out a crank? (fowler)
replace bearings and main seals.
you are just changing the crank only?
Old Feb 24, 2003 | 03:21 PM
fowler!'s Avatar
Default Re: What's involved in swapping out a crank? (sgT)
Crank and rods...
edit: basically stroking a CTR motor to ITR spec. ITR crank and rods...
[Modified by fowler, 4:22 PM 2/24/2003]
Old Feb 24, 2003 | 03:28 PM
Kamin's Avatar
if he is doing rods wouldnt it be a good idea to replace the rings too? because ive never seen anyone replace rods without removing pistons
Old Feb 24, 2003 | 03:30 PM
advanracing62's Avatar
Default Re: What's involved in swapping out a crank? (Kamin)
if it were me and I had the $$ I would replace the berings, rings, and any gaskets. Basically a bottom end kit. Why? just for reassurance....
Old Mar 24, 2003 | 05:40 AM
Muckman's Avatar
Moderator in Chief
Default Re: What's involved in swapping out a crank? (advanracing62)
What are the specific gaskets/seals that are involved?
Old Mar 24, 2003 | 09:23 AM
Crazydave's Avatar
Default Re: What's involved in swapping out a crank? (Muckman)
front and rear main oil seals.
oil pan gasket
you might as well do you water pump and timing belt too
valve cover gasket
you can also do your axle seals on the tranny too if you take it out..
My_EFsedan
Apr 9, 2011 01:36 PM
si90rex
Oct 20, 2010 04:48 AM
deez nuts
Mar 31, 2005 07:04 PM
JDMCRX
May 27, 2004 07:08 AM
Trajic
Oct 8, 2001 11:00 PM
