whats this??? ecu internal
Old Mar 10, 2004 | 02:42 PM
escocrx's Avatar
Default whats this??? ecu internal
thanx in advanced
Old Mar 10, 2004 | 03:28 PM
biggmike2's Avatar
Default Re: whats this??? ecu internal (escocrx)
believe components for operation of knock sensor?
Old Mar 10, 2004 | 03:37 PM
biggmike2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PGMFI.ORG &raquo;</TD></TR><TR><TD CLASS="quote">the knock board is a circuit board (seperate from main ECU PCB) mounted in the top-right hand corner of DOHC Vtec ECUs having a Knock Sensor. </TD></TR></TABLE>
http://www.pgmfi.org/twiki/bin...Board
Old Mar 10, 2004 | 05:20 PM
Kataku2K3's Avatar
Default Re: (biggmike2)
Yup, that's the KS board.
Old Mar 10, 2004 | 06:12 PM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
Default Re: (Kataku2K3)
wut would happend if i remove that board on an attemp to remove the knock sensor from the ecu.... u guys think it would work?
Old Mar 10, 2004 | 06:20 PM
mmuller's Avatar
Mad Scientist
Default Re: (H22AEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AEG &raquo;</TD></TR><TR><TD CLASS="quote">wut would happend if i remove that board on an attemp to remove the knock sensor from the ecu.... u guys think it would work?</TD></TR></TABLE>
I would not think so...but not sure
You could just get the ecu chipped and cancel the ks
Old Mar 10, 2004 | 06:30 PM
biggmike2's Avatar
yep chip it to get rid of it or sell to me and ill get u one with out
btw it looks to be already chipped if thats ur ecu
Old Mar 10, 2004 | 06:33 PM
Kataku2K3's Avatar
Yup, looks like a socket in the 27256 slot. Good eyes, hehe
Old Mar 10, 2004 | 09:40 PM
aaaabbbb's Avatar
Default Re: (mmuller)
hmm.. wut kindn of chip?? cuz i got hondata.. and if i have to remove that chip than its hopeless
Old Mar 11, 2004 | 12:05 AM
iH8RICERZ's Avatar
if in fact that is a eprom sitting in a socket, all you have to do is pop it out of its socket..........if your using that ecu for hondata, then leave that rom in there......hondata's roms should be 29c256. It could also be the stock rom......
Old Mar 11, 2004 | 07:01 AM
Kataku2K3's Avatar
Yea, if you're running Hondata that's the reason you have the socket. I couldn't see nor tell if you had a CN2 socket so I just figured it was a stock ECU. Either way you're fine. If you want to disable your KS, just turn it off with the Hondata.
Old Mar 11, 2004 | 03:36 PM
aaaabbbb's Avatar
thank you
B16B_coupe
Oct 3, 2007 12:32 PM
pcguy760
Apr 10, 2007 06:54 AM
hondaboy4life
Aug 23, 2006 11:55 AM
integg93
Aug 3, 2006 01:17 PM
som3on3_10
Jul 4, 2005 10:33 AM
