Whats the difference between a b16 oil pump and an ITR unit?
Old Apr 25, 2005 | 07:42 AM
Circuit Star-29's Avatar
Default Whats the difference between a b16 oil pump and an ITR unit?
I thought that all vtec oil pumps were the same (between engine series)? Please inform me....
Old Apr 25, 2005 | 09:11 AM
JimBlake's Avatar
Default Re: Whats the difference between a b16 oil pump and an ITR unit? (C-speed Racing)
Where are you & what year's are you talking about? Are you asking about flow properties or any hardware issues?
Since ITR wasn't available in '95, all ITR are OBD-2. That means their oil pump can accomodate the CKF sensor. B16 would be OBD-1 (or 0) so it doesn't have mounting points for that sensor.
I think all OBD-2 oil pumps have the same pressure & flow as the earlier VTEC pumps. In other words, beginning in '96(?) even the non-VTEC pumps have the VTEC flow properties.
Old Apr 25, 2005 | 10:40 AM
Default Re: Whats the difference between a b16 oil pump and an ITR unit? (JimBlake)
pumps in ? here are B16A2 oil pump and B18C5. But judging by what you said vtec pumps of any OBD2 will flow the same....
But are you sure about non-vtec pumps (LS B18B) flowing the same as a vtec pump? I thought the ls pumps help pressure 8lbs lower then vtec pumps.
Old Apr 25, 2005 | 11:38 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Racing &raquo;</TD></TR><TR><TD CLASS="quote">But are you sure about non-vtec pumps (LS B18B) flowing the same as a vtec pump? I thought the ls pumps help pressure 8lbs lower then vtec pumps.</TD></TR></TABLE>I think that was true during the OBD-1 years (& earlier?) You can't just say "LS/B18B" because that doesn't say what year it is.
IF my understanding is correct... (?)
OBD-1 B18B has the lower flow pump. All OBD-2 (B-series) share the same pump as each other (with mounting for CKF sensor), and it has the higher flow matching the OBD-1 VTEC pumps.
Not only that, but even during OBD-1, the only real difference was in the bypass valve of the pump. A stiffer spring or extra spacer to compress the spring, or something like that.
Old Apr 25, 2005 | 09:41 PM
Thank you very much for your input...
Modified by C-speed Ricer at 3:22 PM 7/19/2005
Death_to_Thieves
Feb 26, 2009 12:18 PM
jdm.fanatic
Dec 8, 2007 05:16 PM
endlessdv
Jul 9, 2005 03:11 AM
d.str0y
Jan 24, 2005 05:36 PM
