What's the diff... b18b1? b18a1?
Old Jul 22, 2004 | 09:46 PM
GumballNA's Avatar
Default What's the diff... b18b1? b18a1?
I need to know the difference? between the b18a1, and the b18b1... I am running the b18b1 right now "ls/vtec" but what's the diff. with the a1? will it work in a 96 civic hatch?
Old Jul 22, 2004 | 09:49 PM
boostn420's Avatar
Default Re: What's the diff... b18b1? b18a1? (GumballNA)
a1 is 90-91 teg, they have smaller cams which doesnt matter with lsvtec. It will work just fine, externally the same as b18b.
Old Jul 22, 2004 | 10:01 PM
GumballNA's Avatar
Default Re: What's the diff... b18b1? b18a1? (boostn420)
are you sure! because i don't wanna get a b18a1 and not be able to use it for somereason?
Old Jul 23, 2004 | 02:20 AM
POWERLINEDOHCtor's Avatar
sup gumball ill vouch that boostn420 is right about the block. the only difference is that the coolant temp switch is located on the back of the a1. the temp switch on the b1 is located on the thermostat housing. just make sure you use the b1's thermostat housing/tempswitch/and tube that routes to the water pump.
Old Jul 23, 2004 | 08:10 AM
GumballNA's Avatar
Default Re: What's the diff... b18b1? b18a1? (POWERLINEDOHCtor)
alright guys, thanx.
Old Jul 23, 2004 | 11:52 AM
StyleTEG's Avatar
The B18A has smaller intake ports as well.
Old Jul 23, 2004 | 12:49 PM
michael O's Avatar
Default Re: What's the diff... b18b1? b18a1? (StyleTEG)
Aren't b18a's obd0 while b18b's are obd1-2?
Old Jul 24, 2004 | 01:36 PM
NCchris's Avatar
Default Re: What's the diff... b18b1? b18a1? (michaelOlson)
90-91 B18a's are OBD0, 92-93 B18a's are OBD1, B18b's are OBD1 and 2
HTH
chris
Old Jul 24, 2004 | 05:54 PM
krazie1's Avatar
BANNED
Default Re: What's the diff... b18b1? b18a1? (NCchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote">90-91 B18a's are OBD0, 92-93 B18a's are OBD1, B18b's are OBD1 and 2
HTH
chris</TD></TR></TABLE>
correct and for the LS/VTEC stuff this doesn't matter
but for the all motor LS guys it does
Old Jul 25, 2004 | 09:58 PM
GumballNA's Avatar
Default Re: What's the diff... b18b1? b18a1? (krazie1)
ok so 90-91 OBD-0 92-93obd1? right ?
Old Jul 25, 2004 | 11:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">
but for the all motor LS guys it does </TD></TR></TABLE>
hahaha that was pretty funny i like that. not to bash on the LS guys.
kjsamw
10
Oct 20, 2009 07:37 PM
Will_H
May 1, 2007 03:53 PM
Ransom
Apr 27, 2004 11:21 AM
turbohf
Nov 20, 2003 07:28 AM
B pwr
Oct 12, 2003 01:46 PM
