What is this valve
Old Jul 11, 2004 | 08:01 AM
dr juice164's Avatar
Default What is this valve
Its on the bottem of my intake mani and runs through it, if you will. Its a 1 way valve, the lower part has oil on it. What is this thing
http://home.comcast.net/~bmierz/IMG_0877.JPG
Old Jul 11, 2004 | 08:05 AM
Padronis's Avatar
Default Re: What is this valve (dr juice164)
PCV valve
Old Jul 11, 2004 | 08:25 AM
Default Re: What is this valve (Padronis)
thanks, 1 other thing, should it be a perfect seal when you blow in on it and free flowing when you suck
Old Jul 11, 2004 | 08:56 AM
slo2kgsr's Avatar
All you have to do is pull it out and shake it and it should rattle if it rattles then it is fine.
If you really insist upon blowing the valve you are right when you suck is should be free flowing when you blow it should stick.
Also, I don't think that is a pcv valve (positive crankcase venalation) usally attached to the valve cover. It sucks unburned fumes out of your crankcase and runs them back thru the intake manifold to reburn them and prevent the crank case from going up in fumes.
Fumes are caused by small amount blow by from you piston rings .
Old Jul 11, 2004 | 09:28 AM
Default Re: What is this valve (tegraLS97)
last post on this topic for me, should the other side of the pvc valve be all oiliy and filthy? if thats the PCV valve
Old Jul 11, 2004 | 10:04 AM
Padronis's Avatar
Not all cars have the PCV valve on the valve cover. My 91 integra had it on the IM, and my 98 integra has it on the valve cover. Yes, it will be oily. Over time they become too gunked up with oil and the little ball (check valve) will no longer work. That's when you change it.
91EF919
Jun 14, 2009 02:07 AM
CAM0FLAG3
Apr 1, 2009 06:54 PM
vinuneuro
Apr 24, 2007 06:05 AM
petrv
Aug 26, 2005 02:26 PM
BpuTacoma
Mar 22, 2002 10:00 PM
