what temp does a b16 normally run at?
Old Aug 11, 2010 | 04:24 PM
bakomack's Avatar
Default what temp does a b16 normally run at?
i put a new head gasket on a short block that has approx 8k miles, head is not warped or anything car runs fine. but on my smanager my temp runs between 198 and 202. what temp is my car suppose to run at normally?
my temp needle is allways in the normal position and never goes higher than a little under half on the gauge but I thought they ran at like 185?
what temp do head gaskets blow and heads warp?
Old Aug 11, 2010 | 04:45 PM
fcm's Avatar
fcm
Old Fart
Default Re: what temp does a b16 normally run at?
198-202 is normal, ECTS will turn on the rad fan a about 198. 94
Old Aug 11, 2010 | 05:10 PM
bakomack's Avatar
in my smanager my fans both kick on at 175 but I was worried running at 200 was a little high. what temp starts to hurt things?
Old Aug 11, 2010 | 08:13 PM
fcm's Avatar
fcm
Old Fart
Use a thermo gun to see exactly what the engine coolent temp. is when rad fan turns on, so you know for sure your "smanager" is correct, and read this... http://www.aa1car.com/library/overheat.htm 94
weekendboost
Jun 21, 2019 06:11 PM
pro306
18
Jul 4, 2013 05:35 AM
madcivic31
Jan 29, 2010 09:23 AM
1gEF-8
Acura TL, RL & ZDX
Jul 2, 2005 05:31 PM
HarryB
Jul 20, 2002 11:44 PM
