What are some fuel saving mods
Old Nov 24, 2001 | 10:34 PM
TomTom's Avatar
Default What are some fuel saving mods
what mods can i do that will give me better gas mileage and make the car run better
Old Nov 25, 2001 | 01:26 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: What are some fuel saving mods (TomTom)
less weight and learn to drive "pussyfoot".
What car you got?
Old Nov 25, 2001 | 05:06 AM
rainforest's Avatar
Default Re: What are some fuel saving mods (Mista Bone)
retard your timing....and weight.
Old Nov 25, 2001 | 06:46 AM
Mr.FBR's Avatar
All around vehicle maintainence...good tires (big hulky 17+ sizes won't help) Frequent oil changes, good air filter, good plugs, recent wires...don't need expensive aftermarkets, stock is good! Even things like having the right amount of air in your tires...Keeping the revs down is a must if you want to conserve fuel...and doing speed limit will help too althought isn't fun.
Old Nov 25, 2001 | 10:48 AM
CivicV10@18000rpm's Avatar
Default Re: What are some fuel saving mods (rainforest)
Retarding the igntion timing decreases fuel mileage and HP around the low RPM range. Mixture will burn later in the power stroke even though EGT's will tend to go up...because more of the mixture is burning in the exhaust manifold/header than in the engine itself. And to compensate for the lost HP due to decreased ignition timing, the accelerator has to be pressed more decreasing fuel mileage even further.
Old Nov 25, 2001 | 10:56 AM
Duck Sauce's Avatar
Default Re: What are some fuel saving mods (CivicV10@18000rpm)
That's true. Also look into getting an upgraded ignition system. Coil and wires. That way you get better MPG and throttle response.
Old Nov 25, 2001 | 11:15 AM
Greyout's Avatar
APEX'i V-AFC
Old Nov 25, 2001 | 12:26 PM
csufweed's Avatar
intake, headers, exhaust, ignition.
Old Nov 25, 2001 | 07:42 PM
Gasoline Fumes's Avatar
Narrow tires
custom gearing
convert to a two cylinder and turbocharge it
some time in a wind tunnel
Old Nov 25, 2001 | 11:18 PM
xJ.SLOTHx's Avatar
keep it stock
Old Nov 26, 2001 | 04:29 AM
BoM's Avatar
BoM
Default Re: What are some fuel saving mods (ian)
buy a cx civic
Old Nov 26, 2001 | 02:20 PM
Crazydave's Avatar
Default Re: What are some fuel saving mods (BoM)
remove sound deadening material
swap in a VX motor
or one of those new hybrid fuel/electric motors
Cut out the floorboard and flinstone it
Old Nov 26, 2001 | 04:08 PM
fsarfino's Avatar
Default Re: What are some fuel saving mods (Crazydave)
think Honda Insight 80 mpg and forget about speed
Old Nov 26, 2001 | 05:43 PM
B19CivicHB's Avatar
Default Re: What are some fuel saving mods (dohcvtec16)
Buy one of these.... 400mpg, 400 hp... where do i sign up?? http://www.supercars.net/SDBQ?y=2001...note%20Concept
Old Nov 26, 2001 | 08:54 PM
John's Avatar
New User
keep it stock
i actually get better fuel economy now than i did when i bought my car 4.5 years ago... 28mpg city... the key? tuning your car on a dyno (with a V-AFC), driving more efficiently (yes, i too drive my car as hard as you all do), and proper maintenance...
Old Nov 26, 2001 | 09:00 PM
Revtoredline's Avatar
There is a new product out but I 'm not sure how good it is. Its good the Tornado and its a relatively simsple device that you can install in your air intake. They say it can increase mileage from 5-20% just installing it. The theory is it provides a sideways 'tornado' that I guess allows better air intake into your engine. Check out http://www.tornadofuelsaver.com I havent gotten one yet but check it out.
RSX rules
Old Nov 26, 2001 | 09:14 PM
nfn15037's Avatar
Default Re: What are some fuel saving mods (7800redline)
Tornado =
Dont waste your $.
ridgeline53
Dec 9, 2013 10:37 AM
Poorb0i
Apr 22, 2008 03:11 PM
winnerpl
Apr 12, 2007 01:13 PM
fredtoast
Nov 11, 2004 07:40 AM
97LudeSH
Sep 5, 2001 01:23 PM
