what size rod?
Old Apr 29, 2003 | 10:40 PM
rocket_R's Avatar
Default what size rod?
i heard that using longer rods will help top end, but how do you know what size to use without running into problems? looking for new rod for a built h22 turbo
Old Apr 30, 2003 | 03:20 AM
BabyDaddy's Avatar
Default Re: what size rod? (rocket_R)
Eagle offers some longer rods for the B series but I don't know about the H series. The only way to know how long you can use is math my friend. Use the deck height and get your stroke/rod length/compression height to figure it out. If you can get some longer rods, I'd imagine that you would have to order custom units (big $). Then you would have to order custom pistons with a different compression height (again, big $). Unless you deckplated your block (once again, even bigger $). HTH
92_civic_eg
Mar 19, 2014 04:02 AM
92TypeR
33
Aug 1, 2007 01:05 PM
riceball777
Dec 3, 2005 02:25 PM
rocket_R
May 1, 2003 06:41 AM
gsrvx
Dec 15, 2001 11:27 AM
