Spark Plug Size????
Spark Plug WIRE Size????
Hey, I was thinking about picking up some NGK IRIDIUM PLUGS WIRES and was wondering if the size of the plug is important? Am looking at a 9MM. will this have any effect on my car?
My car is a 99 SI
with a built b16.
most mods added.
Modified by thai-lorn at 2:10 PM 1/15/2007
Modified by thai-lorn at 2:11 PM 1/15/2007
My car is a 99 SI
with a built b16.
most mods added.
https://honda-tech.com/zerothread?id=1811161
https://honda-tech.com/zerothread?id=1645037
https://honda-tech.com/zerothread?id=1568589
There's a few to get you started. Search "spark plug gap" and you'll get alot of results to figure out the correct gap for the plugs you have.
Re: Spark Plug WIRE Size???? (thai-lorn)
The plug socket end should fit fine. The wire size is usually rated by how thick the insulator is, 8mm, 9mm, etc. Thicker won't hurt, but it's not necessary.
