what should i do next? with my setup
Old Mar 30, 2005 | 12:47 AM
jazz1320's Avatar
Default what should i do next? with my setup
i just got a 96 dx coupe, with a 00 b20 swap i got I/E and aem fuel rail and aem fuel pressure reg.. i am running a stock dx ecu. i want my car to run better. i heard b20s dont get the right around of fuel. when i changed the old plugs, my boy said told me im runnin lean. i know i need a B&M fuel pressure gauge to tune my FPR. how will i know when im not running lean any more? i just got a ls ecu, it lets me rev alot higher, but wheni ilde at a stop light, the motor shutts off WHY??
Modified by jazz1320 at 5:40 AM 4/3/2005
Modified by jazz1320 at 9:18 PM 4/6/2005
Modified by jazz1320 at 3:05 PM 4/8/2005
Modified by jazz1320 at 3:36 PM 4/12/2005
Old Mar 30, 2005 | 01:11 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: what should i do next? with my setup (jazz1320)
Old Mar 30, 2005 | 09:40 AM
zacdaddy77's Avatar
is it a b20/vtec or just b20? if its not vtec but a vtec head on it (b18c1,b18c5,b16)
Old Mar 30, 2005 | 06:11 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: what should i do next? with my setup (zacdaddy77)
Old Apr 2, 2005 | 08:40 PM
jazz1320's Avatar
Default Re: what should i do next? with my setup (BLUE EH3)
bump
Old Apr 4, 2005 | 07:14 PM
jazz1320's Avatar
any one??
Old Apr 5, 2005 | 01:54 AM
SlowReaction's Avatar
You need to get the correct ecu before you do anything else. I recommend running a obd1 jumper and pickin up a ls ecu. Though this ecu isnt designed for the b20 it iwll work way better then your dx ecu. You can also get a chip or something for the ls ecu which will help out also.
Old Apr 6, 2005 | 12:15 PM
jazz1320's Avatar
Default Re: what should i do next? with my setup (SlowReaction)
i got the 98 ls ecu installed today. i can rev alot higher, but the car just shuts off sometimes? i want to install my B/M fuel pressure gauge today also, so i will know if im still running lean?
Old Apr 6, 2005 | 12:36 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
The only way you are gonna know if your running lean or rich in detail is with a wideband o2 sensor. you can guess, but its kinda hard to dial in without some sort of fuel computer.
Old Apr 7, 2005 | 07:28 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: what should i do next? with my setup (JDM_Ej)
DID HE GET A BAD ECU?
Old Apr 12, 2005 | 06:37 AM
jazz1320's Avatar
i bumped my fuel pressure to 42psi and the car doesnt shut off! is that too high?
Old Apr 12, 2005 | 10:22 AM
suckawillis's Avatar
tahts cool. leave it
crazyhondahead
Aug 12, 2011 10:47 PM
92integraVTECgsr
Jan 8, 2007 03:50 PM
K20Ej1
Mar 13, 2006 09:55 AM
1hotcivicSi
30
Feb 16, 2004 03:15 PM
blufke
Jun 19, 2002 10:20 AM
