what is this sensor
Old Oct 9, 2010 | 04:24 PM
horn12007's Avatar
Default what is this sensor
what are these sensors? and do I need the one on the left hooked up? The wiring sux (custom/chopped). and I cant find the connector to this wire. and I know there are many other connectors that look the same but I know where all those go.......so what is it and does it (the left one) have to be connected. thanx
Old Oct 9, 2010 | 04:38 PM
reddcoupe's Avatar
Default Re: what is this sensor
oil pressure switch and knock sensor
Old Oct 9, 2010 | 05:05 PM
horn12007's Avatar
the one on the left is the knock sensor? didn't think b18a1 had those
Old Oct 9, 2010 | 05:31 PM
reddcoupe's Avatar
yea had one on my motor took it out using the hole as a breather
Old Oct 9, 2010 | 08:25 PM
horn12007's Avatar
sweet. i guess the old motor didn't have it hooked up either.
Old Nov 10, 2010 | 09:00 PM
horn12007's Avatar
hey im gonna reopen this thread.....I don't think that sensor in the left is a knock sensor, thinking its an oil pressure sensor......but since my wiring is jank, it doesn't have a connector for it, but I do have a canister coming off the lsvtec canister that has a wire running to it, I think it reads oil pressure???? im confused. can anyone else help. I will try to get more pics
Old Nov 10, 2010 | 09:06 PM
horn12007's Avatar
......or is it the fan switch.....im confused as ****. just need to know if the left plug needs hooked up. thanx
Old Nov 10, 2010 | 09:40 PM
reddcoupe's Avatar
what motor u got is it obd 1 0r 2 and what wire harness u using
Old Nov 10, 2010 | 11:10 PM
horn12007's Avatar
its lsvtec. think the block is obd1. its got a hack job 0bd0 wiring harness that im gonna turn into obd1
Old Nov 11, 2010 | 06:16 AM
Kova23's Avatar
no doubt the knock sensor on the left and the oil pressure sensor on the right. fan switch is on thermostat cover
Old Nov 11, 2010 | 06:29 AM
kyden's Avatar
its a b18a, that is the fan switch.
Old Nov 11, 2010 | 08:08 AM
HondaPartsHero's Avatar
Technical Hero
It's a fan switch that activates by oil temp instead of coolant temp. I believe only the automatic b18a had them. You won't need it unless your engine doesn't have a coolant activated fan switch.
Old Nov 11, 2010 | 08:56 AM
horn12007's Avatar
haha 2 people vote for knock sensor and two for fan switch? its got a vtec head on it if that matters. I would rather just have my own switch to turn the fans on.
Old Nov 11, 2010 | 09:26 AM
Chiovnidca's Avatar
It's a fan switch. If it was a knock sensor it would be mounted higher. What year is the engine? I dont think any hondas used knock sensors before obd2 came out.
Old Nov 11, 2010 | 11:03 AM
horn12007's Avatar
93 yea i dont think its the knock sensor either
Old Nov 11, 2010 | 11:18 AM
92_civic's Avatar
its definitely the fan switch, not a knock sensor
Old Nov 11, 2010 | 01:53 PM
horn12007's Avatar
alright thanx
Jaz760
Apr 7, 2012 06:37 PM
Freeclowns
Mar 30, 2012 09:22 AM
TylerC161
Sep 20, 2006 09:57 AM
migizzel
May 9, 2006 10:44 PM
DC2 to AP2
Aug 23, 2004 07:46 AM
