What seals needed when rebuilding bottom end?
Old Jun 21, 2002 | 06:32 PM
B19CivicHB's Avatar
Default What seals needed when rebuilding bottom end?
Is it just the front main crank seal?
thanks!
-Nick-
Old Jun 21, 2002 | 07:12 PM
BreakStuff's Avatar
New User
Default Re: What seals needed when rebuilding bottom end? (B19CivicHB)
If you remove the crankshaft, replace the seals at both ends..
If the crankshaft is left intact then it would do no harm to leave the original seals, of course assuming none are leaking..
Old Jun 21, 2002 | 10:11 PM
earl's Avatar
You can buy a lower end kit for about $40 or so. You get the pan gasket, front and rear seals, oil pick-up gasket and 6 o-rings for various spots.
Old Jun 22, 2002 | 12:48 AM
dlric's Avatar
Default Re: What seals needed when rebuilding bottom end? (earl)
sweet where would one pick this kit up..are you meaning a honda/acura dealership directly?
Old Jun 22, 2002 | 08:05 AM
earl's Avatar
Default Re: What seals needed when rebuilding bottom end? (dlric)
I'm not sure if Honda sells a kit or not. I sell them for $40 plus shipping. That's almost the price of buying the pan gasket alone from Honda. I'd check some local shops in your area for pricing. You may do better locally.
Earl
Old Jun 22, 2002 | 11:29 AM
dlric's Avatar
$40+shipping?? you are the man! i'll be talkin to you in a few weeks.
Devo94ac
Mar 14, 2007 05:41 PM
s1ngle
Oct 17, 2006 11:38 PM
flip1199
Jun 22, 2004 09:29 AM
lazyguy
May 22, 2002 11:38 AM
