What to Rev limit to use?
Old Feb 9, 2004 | 11:57 AM
EGJDM's Avatar
Default What to Rev limit to use?
Hey
Right now I am in the process of building up my ls vtec turbo I know that a lot of people ask " how high can I rev my motor" I am wanting to know this because I am thinking in terms of what turbo an tranny to use for my motor. So all I want is knowledgeable people to reply what would be a safe rev limit to use?
Old Feb 9, 2004 | 03:24 PM
EGJDM's Avatar
Default Re: What to Rev limit to use? (EGJDM)
bump
Old Feb 9, 2004 | 03:36 PM
GreenBean's Avatar
Without a crank girdle, no more than stock red-line on the LS engine...If you have a crank girdle I would hope you would be ok at 8,000....You might want to link this to the "Forced Induction" forum
Old Feb 9, 2004 | 03:44 PM
Katman's Avatar
Default Re: What to Rev limit to use? (GreenBean)
...and to add
The only real way to see where a legitimate redline should be set, would be on a dyno. A dyno shows where your powerband is at and where it dies off at.
Old Feb 9, 2004 | 03:52 PM
GreenBean's Avatar
Default Re: What to Rev limit to use? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">...and to add
The only real way to see where a legitimate redline should be set, would be on a dyno. A dyno shows where your powerband is at and where it dies off at.</TD></TR></TABLE>
Yea, I forgot about that part...Thanks Katman
Old Feb 11, 2004 | 11:19 AM
EGJDM's Avatar
TTT
Old Feb 11, 2004 | 02:59 PM
slammed_93_hatch's Avatar
what the **** else do you want. on a stock ls block its not really suggest to rev higher then stock rev limit. but if you have th bottom end built then you need to get to a dyno. see were you power falls off then set the rev limit around there. is that spelled out enough for you
Old Feb 11, 2004 | 03:01 PM
mattssi's Avatar
Default Re: What to Rev limit to use? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">what the **** else do you want. on a stock ls block its not really suggest to rev higher then stock rev limit. but if you have th bottom end built then you need to get to a dyno. see were you power falls off then set the rev limit around there. is that spelled out enough for you</TD></TR></TABLE>
Why even reply?
Old Feb 11, 2004 | 03:21 PM
Default Re: What to Rev limit to use? (mattssi)
so that he would not continue the TTT. and why do you reply? kinda hypocritical to reply to a topic that has been aswered with then why reply
Old Feb 12, 2004 | 08:58 AM
EGJDM's Avatar
Did you ever think that maybe people want to see what more people other than you have to say about the issue. And yes the bottom end is going to be fully built.
Old Feb 12, 2004 | 12:29 PM
tegmech's Avatar
EGJDM, if you would have searched for a minute you would have found you answer. You are not near the first to bring up this topic. slammed_93_hatch, whats the point of flaming him. Just makes ht look like ****
Old Feb 12, 2004 | 01:35 PM
EGJDM's Avatar
Default Re: (tegmech)
I have searched and have read them!!!!!
Old Feb 12, 2004 | 01:39 PM
tegmech's Avatar
if you have read ALL the posts pertaining to ls/vtec and revlimit and ALL posts about the reasons for changing revlimit, then why bother posting this topic. Because then you would already know the answer. Im not trying to start a flame war.
Old Feb 12, 2004 | 03:05 PM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">so that he would not continue the TTT. and why do you reply? kinda hypocritical to reply to a topic that has been aswered with then why reply</TD></TR></TABLE>
Why bring all this hate and anger here and take it out on other people? you could have responded in a better way... Don't you think?
Old Feb 12, 2004 | 03:16 PM
EGJDM's Avatar
tegmech Maybe there is people that would reply that may of never replied to the other ones. If you don't have anything useful to say about this topic please don't bother to reply!!!!!!!!
Modified by EGJDM at 4:30 PM 2/12/2004
Old Feb 12, 2004 | 04:59 PM
Jason123's Avatar
what a DICK !!!!!!!!!!!!! I wish I could be as cool as you, NOT. *******
Old Feb 12, 2004 | 08:46 PM
tegmech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGJDM &raquo;</TD></TR><TR><TD CLASS="quote">tegmech Maybe there is people that would reply that may of never replied to the other ones. If you don't have anything useful to say about this topic please don't bother to reply!!!!!!!!
Its not what people think, its the physical stresses that your head can take. Like i said, if you search you would know this already. Im going to stop replying because your not going to get the point.
Old Feb 12, 2004 | 09:06 PM
EGJDM's Avatar
Default Re: What to Rev limit to use? (tegmech)
You have nothing to input about this topic so don't reply okay. Let those who will reply reply and if no one does no does. I you have ever read multiple post omn a search you will see that ever persons input could be contriticted by the previous persons input.
Old Feb 12, 2004 | 11:35 PM
Default Re: What to Rev limit to use? (Jason123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason123 &raquo;</TD></TR><TR><TD CLASS="quote">
hey **** off the dues answer was answered to full CORRECT extent shut up with your useless posts
blackeg
Engine Management and Tuning
Apr 7, 2015 04:38 PM
DC_Legacy
Apr 5, 2015 12:04 PM
integraboosted
Sep 15, 2006 10:12 PM
fulldragcrx
Feb 7, 2005 02:34 PM
fulldragcrx
Feb 5, 2005 05:19 AM
