what power adapter for 31-LED Worklight?
Old May 28, 2016 | 07:47 AM
crxaddikt's Avatar
Default what power adapter for 31-LED Worklight?
i know this is'nt really a car or honda oriented question, but i just did'nt know what type of forum to ask it in, and it is a worklight, which people use to work on their car's with, so its sort of related....
a few months ago i bought a rechargable 31-LED worklight from Autozone, the brand is SURE BILT, i need to recharge it now, but now i'm not sure what power adapter it came with in the package ?,
i threw the package away, and it did'nt come with instructions, and it does'nt even list what DC/AC, volt/amp it needs for plugging the correct power adapter into it, i don't want to plug in the wrong power adapter and damage it, i took it to autozone and thought i could look at one thats new in the package to see which power adapter it comes with, but they don't even carry them anymore, and he told me to just call autozone customer service and ask them, and i searched all over google and could'nt even find anything about the brand SureBilt ? i only saw DuraPower, which carries worklights that look identical except with a different brand listed on it.
usually i keep the power adapters i use for important devices that i use often in a kitchen drawer or some place thats always easy to find when i need it, but i don't know where i put it ?, or it might be one that i saw, which fits it, but just not for sure?
it is just like this one, in the pic :
LINK
you know any way how i could find out what rating or type of power adapter this worklight supposed to use with it ??? thanks
Old May 28, 2016 | 10:48 AM
fcm's Avatar
fcm
Old Fart
Default Re: what power adapter for 31-LED Worklight?
Why not just go to AutoZone and check it out? 94
Old May 28, 2016 | 12:32 PM
Calif_Kid's Avatar
I did a quick search for 'surebilt 31 LED Worklight', and saw an Autozone link on E-bay at Autozone Surebilt 31 LED Bright Work Light L17 1139B | eBay. It mentions that the light has a 3.6V 1000MA Ni-MH battery, which is the same voltage as the link that you showed, but the E-bay ad doesn't mention anything about if a charger is included, and if it is, then what voltage and current the charger is rated at. Maybe you can send a message to the Autozone E-bay ad and ask if a charger is included, and if it is, then what voltage and current it is rated at. Personally, when I wanted to get an extra charger for some small video cameras that I use at the track, I ended up going to a local electronics surplus shop that sells used stuff, and paid say $3-5 for the charger, but just needed to make certain that the connector, voltage, and current were right. - Jim
Old May 30, 2016 | 12:00 AM
crxaddikt's Avatar
that does suck, how it seems so difficult to simply try to find specifications about a product you bought ?, and they don't even list it (the DC V info) on the device itself ?, i thought that it required due to safety hazard / electrical labels and stuff ?, but i did go up to AutoZone to just look at the same worklight in its package and see which power adapter is in it, but the one i went to did'nt even carry it any longer, and he just said for me to call autozone customer support number, i did but it was the weekend and closed, so i sent a message instead, but they just had a reply saying they will look into the inquiry and get back to me later,
then i called a different AutoZone close by, and they checked and he said they do carry the 31-LED Worklight, so i went up there and looked at it, and right away i could see that the power adapter looked exactly like the one i had in mind, that i thought was the one that came with it (which i had), and so at least i confirmed which one it was.
i plugged it in an outlet and let it charge about 5 or 6 hours, (said 4-6 hours should charge it fully), weird thing is the charge indicator light never lit up at anytime ?
i guess it just supposed to turn red or green or whatever once you plug it in, showing its in the process of recharging, but it still probably charged it up, i don't really know, the reason is cause the light still worked before charging it, after charging , it seemed slightly brighter but could'nt tell if it fully charged or not, i just figured it was time to recharge it since i've had it for months and assumed it was probably time to charge it up, to make the light bright as possible, i can't believe how long the charge lasts ?!!, i thought the light would of died down a long time ago?, but it just kept working ? it also has a car cigarette charge cord too if needed.
civicvtec44
May 16, 2009 09:58 PM
ShaneD16
Nov 12, 2005 03:17 PM
civic_speed99
Audio / Security / Video
Apr 20, 2005 07:05 AM
94B18B1Teg
May 27, 2004 11:47 AM
lerroy
May 10, 2004 07:28 PM
