What oil to use when breaking in a motor?
Old Jun 16, 2005 | 08:43 PM
civiwhip's Avatar
Default What oil to use when breaking in a motor?
Im putting in ctr piston in my b16 and i dont know what oil to use? Synthetic or non-synthetic? What weight? Please help me out.
Old Jun 16, 2005 | 08:47 PM
337 GTI 1.8t's Avatar
Default Re: What oil to use when breaking in a motor? (civiwhip)
if the clearances are stock for the bottom end bearings, use the weight that is on the oil cap. 5w-30...
IMO synth is good for long-interval oil changes and better stability if you really are hard on the engine, but dino oil works fine for most apps, you just should not expect to go 10k between changes on dino.
Old Jun 17, 2005 | 07:46 AM
PURPLETERROR aka BIGMATT's Avatar
Cheap sae 30w
Old Jun 17, 2005 | 08:21 AM
full_race_eg6's Avatar
Default Re: What oil to use when breaking in a motor? (PURPLETERROR)
agreed becasue if you break in right youll be changing oil 2-3 times only on the last oil chage after its broken in use synthetic, i would recomend mobil 1 10/30 syn. dont use castrol or any synthetic blend get full syn.
Old Jun 17, 2005 | 04:28 PM
FERIOkid's Avatar
Default Re: What oil to use when breaking in a motor? (full_race_eg6)
i used some regualar penzoil 10W30 with my currect setup, i will be switching to 5w30 mobile1 synthetic at 2000 and have given the motor and oil change every 400-600 miles
my setup =
b18b1 in a 1993 civic sedan
stock head
je pistons and rings (9:1 forged)
eagle rods (h-beams) w/ arp rod bolts
arp headstuds
acl duraglide bearings (rod and main)
rebalanced everything (crank, pisonts, rods, flywheel)
cylinders were rehoned
thats it for the motorwork so far the motor is just awaiting a little snail
Old Jun 17, 2005 | 05:38 PM
PrettyLude's Avatar
just something something that is not synthetic
Old Jun 17, 2005 | 08:57 PM
snowseeker's Avatar
Default Re: (PrettyLude)
Non detergent 30w. Or vegetable oil for 10 min breakin.
Old Jun 18, 2005 | 11:21 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
don't use synthetic when breaking in an engine. break it in with conventional, then switch to a full synthetic after a few thousand miles.
svhiker
Aug 4, 2017 03:19 PM
mfisher1967
Honda Civic (2006 - 2015)
125
Jun 5, 2007 11:41 AM
NA JDM GSR
Nov 21, 2006 06:24 AM
turbochargeb18c
Jun 18, 2005 04:20 PM
StinkyTofu
Apr 9, 2002 10:47 PM
