What is O-ring a block?
Old Sep 24, 2003 | 04:28 AM
Garrett's Avatar
Default What is O-ring a block?
I want to know what is O-ring a block? If you have some picture it will be very well
Old Sep 24, 2003 | 11:18 AM
Garrett's Avatar
Help please
Old Sep 24, 2003 | 11:28 AM
Garrett's Avatar
Default Re: (Garrett)
I search and found about 300 topic and don't see what is O rings
Old Mar 16, 2005 | 11:16 PM
99teggsr's Avatar
Bringing this post back from the dead. I also want to know what is o-ringing ? And when is it necessary ?
Old Mar 17, 2005 | 06:53 AM
PrettyLude's Avatar
it is not necessary, an O-ring goes on top of a sleeve to help the headgasket to have a better seal, i have found that using the step deck option is alot better and consitent
Old Mar 17, 2005 | 07:23 AM
Wes V's Avatar
Default Re: (PrettyLude)
I didn't really know that O-rings were used on Honda engines due to the open deck configuration, but is common on high compression domestic engines.
What happens is that there is a circular groove cut in the block's deck surface around the cylinder (the head surface). Then a copper (I believe) o-ring is set in in the groove (between the block and head gasket). This ring helps keep the compression from blowing out the head gasket.
If you want more information, you may ge better off searching through Domestic car web sites. You could try Chevelles.com
Wes
Kyle Hufford
Jun 18, 2019 09:41 AM
The Show Stopper
Oct 16, 2009 06:34 PM
W O T
Feb 13, 2005 10:06 AM
TeamCracka
Feb 16, 2004 06:34 PM
nighthunt6
Mar 11, 2002 05:15 PM
