What needs to be re-wired on a 00 civic obd conversion
Old Mar 4, 2004 | 01:37 PM
warwagon's Avatar
Default What needs to be re-wired on a 00 civic obd conversion
i have a 00 cx and i put my p06 in and it runs but i need to rewire for the 2 to 3 wire iacv, just curious what i need to do
thanks
Old Mar 4, 2004 | 05:28 PM
Fobtions's Avatar
Default Re: What needs to be re-wired on a 00 civic obd conversion (warwagon)
ecu pin modifications-
move pin a14 to a12
then unpin a13 and leave it out.
a12 is on the first plug second row first pin, a13 and a14 are the pins next to it to the right. this is lookin into the ecu
three wire iacv plug mods.
unpin the orange wire(should be on the left side) and dont use it at all.
the remaining wires need to be cut off and spliced onto a normal two wire iacv
Old Mar 4, 2004 | 11:10 PM
warwagon's Avatar
Default Re: What needs to be re-wired on a 00 civic obd conversion (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">ecu pin modifications-
move pin a14 to a12
so i need to get a different iacv or just rewire the cx iacv like stated above
and i am assuming you are speaking of the obd1 side of the conversion harness that i need to move the pins around on
Old Mar 4, 2004 | 11:14 PM
Fobtions's Avatar
no, u need to move the original obd2 ecu plugs.
and this is so u can use any two wire style iacv
Old Mar 4, 2004 | 11:22 PM
warwagon's Avatar
ahh so now i have to get another y8 manifold from a manual tranny car to solve this problem
Old Mar 5, 2004 | 02:55 PM
Fobtions's Avatar
yah i ran into this problem the other day when doin a y8 swap on a friends car. the manifold has the spot for the 2 wire iacv but it is blocked off. and it had that wack air injection at the injectors.
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
BlackHXCoupe
Jan 19, 2010 11:08 AM
95accordh22a
Mar 15, 2005 11:48 AM
Loaded Butane
Feb 23, 2002 05:08 PM
