What is the meaning of Over bore and Honeing?
Old Jan 21, 2003 | 04:32 AM
SupaFly_Honda's Avatar
Default What is the meaning of Over bore and Honeing?
and why does is it need to be done when putting in new pistons and rods?
Old Jan 21, 2003 | 05:58 AM
b19coupe's Avatar
Default Re: What is the meaning of Over bore and Honeing? (SupaFly_Honda)
Honing is refinishing the cylinder walls with a honing stone to give a good crosshatch finish for the rings to seat in against. It removes any light scratches and helps the rings to seal properly. You can reuse the standard bore pistons in this case, with new standard size piston rings, of course.
Boring of the engine block is done when the cylinder walls are too damaged for the rings to seal properly. The block is bored using a boring bar and bit to achieve the desired bore. In this case the pistons that are installed in the engine are oversized, along with the rings. The cylinders are then finished up with a hone and it is ready to go.
Old Jan 21, 2003 | 06:53 AM
sauceman's Avatar
Default Re: What is the meaning of Over bore and Honeing? (b19coupe)
Ep3tat98
K Series
Feb 3, 2016 10:20 PM
Ricextacy
Jul 24, 2009 01:24 PM
da_rimrocka
Nov 30, 2005 12:14 PM
AgentJam
Jul 22, 2004 06:22 PM
ludelvr
Nov 26, 2003 03:56 PM
