What makes the gear shifter spring to the center of the shift pattern? Is it in the Transmission, or
Old Jun 30, 2006 | 07:31 PM
dave1234's Avatar
Default What makes the gear shifter spring to the center of the shift pattern? Is it in the Transmission, or
My shifter flops left and right, when in netural or in any gear. Everything shifts fine but it has no 'spring.' Please help, thank you!
Old Jun 30, 2006 | 08:07 PM
Chiovnidca's Avatar
Default Re: What makes the gear shifter spring to the center of the shift pattern? Is it in the Transmission
Anybody been messing with the trans? Have any of the detent spring bolts loosened up?
Old Jun 30, 2006 | 11:27 PM
dave1234's Avatar
Are the 'detent spring bolts' the same as the spring pin on the shift rod? Is my problem internal or external of the transmission?
Old Jul 27, 2006 | 09:05 AM
sumchillguy's Avatar
Yea, i have a similar problem right now also..be great if someone out there could help.
Old Jul 27, 2006 | 09:51 AM
Mista Bone's Avatar
D Tranny Guru
Sounds like the o rings in the bottom of the shifter are just melted from exhaust heat.
Time for a new shifter.
Whatislove
Honda Civic (2001 - 2005)
15
Apr 2, 2011 05:47 PM
illusion
Feb 6, 2002 02:00 PM
