What to look for when buying head?
Old May 18, 2016 | 05:53 AM
civilsantana's Avatar
Default What to look for when buying head?
searched all over but keep finding trouble shooting threads..anyway im buying a gsr head to start my b20v project and i wanted to know any tips or giveaways i should look for when inspecting the head? This is my first head or first time really dealing with parts of a motor. I know that warpage can be an issue, bent valves, etc but the guy says the head only has 800 miles because it was machined and had a slight port job not to long ago, i will attach some pics of the head and see what you guys think, Any tips are appreciated
Old May 18, 2016 | 07:48 AM
fcm's Avatar
fcm
Old Fart
Default Re: What to look for when buying head?
Spend the money and have a machine shop inspect it before you buy it, if owner does not agree, find another head.
You can also buy from a dealer, that will give you warranty. 94
Old May 18, 2016 | 08:05 AM
What can i expect to pay for a machine shop to inspect it?
Old May 18, 2016 | 08:29 AM
cruizinmax's Avatar
Quick and dirty way to check for bent valves is pour a little gas or other solvent in the intake and exhaust ports and see if it leaks in the combustion chamber. Also check for oil leaking down the valve stems in the port. Could indicate leaking valve seals or worn guides.
Old May 18, 2016 | 08:51 AM
Thats a good one! But i can see the valve seals clearly with the cams and everything assembled?
Old May 18, 2016 | 12:08 PM
cruizinmax's Avatar
If you look in the port and see any oil leaking down the valve stems from the guide there is an issue.
Old May 18, 2016 | 01:00 PM
king06's Avatar
That head looks like it has a lot more than 800 miles. Those chambers show it.
Old May 18, 2016 | 02:15 PM
fcm's Avatar
fcm
Old Fart
Was going to say that looks like a hard 800 miles. check around your area machine shops for pricing, I have a shop here that will do a quick look for $20 and $75 for a complete look see, with recommendations and warranty on the inspection if nothing needed. 94
Old May 19, 2016 | 05:17 AM
thanks yall this is exactly what i needed to know
Old May 19, 2016 | 03:56 PM
holmesnmanny's Avatar
He was actually being serious. That's how you test if valves are sealing.
Old May 19, 2016 | 09:03 PM
king06's Avatar
No, you need to take the cams out so all the valves are closed.
thenext
11
Apr 16, 2011 12:15 PM
Stationwagon
21
Sep 8, 2009 11:56 AM
standbackimapro
Sep 25, 2006 09:47 AM
inspyral
Mar 14, 2003 02:57 PM
