what headgasket to use?? higher cr..
ok, after extensive search, im left with the more popular choice, Spoon and Mugen. But a while back, i wanted to lower my cr because it was too high and a h-t member worked for carsmetic* and said they also made headgaskets(well he could make them) to fit my needs... WHat do u guys recommend. Is it a good idea to buy a stock headgasket and take the middle layer out? any problems from personal experience... anything would help. THANX
just calculate your compression
before you decide!!
here is a link so it could help you
http://www.c-speedracing.com/h...c.php
hope it helps
before you decide!!
hope it helps
As beerman stated, if you take out a layer of the stock headgasket it is going to raise to compression due to the head being closer to the block. Which obviously if your trying to lower your compression you need a thicker one then what you have now.
my bad... i want to higher my cr. (too early in morning, posted right before class).. now i know i can take out a layer and hat highers my cr, but are there any consequences for this.
here:
http://www.cometic.com
In the catalog it does not show different thicknes, they only show stock.Call them and ask them.
so wouyld there be any problems with just a stock honda headgasket without the middle layer???????? ANYONE run this on their car with no problems... any suggestions would help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">In the catalog it does not show different thicknes, they only show stock.Call them and ask them.</TD></TR></TABLE>
they make thicker ones , I run one for the past year , 15 track weekends and no problems at all.
What kind of headgasket do you have now? If you are using a stock one then getting another stock one and removing the middle layer would raise your compression ratio. If you have some sort of aftermarket gasket, then getting a stock one will probably lower your CR, depending on what size you are running now.
-Ace
-Ace
VTEC-DA
Jan 18, 2003 02:06 PM
