What happened to this engine?
Old Dec 22, 2008 | 01:34 PM
JordanCivic's Avatar
Default What happened to this engine?
Hi guys, i know the pics arent great, but anyone have any idea what the hell happened here.
Old Dec 22, 2008 | 01:45 PM
dcvt16's Avatar
Default Re: What happened to this engine?
catastophic failure...
Old Dec 22, 2008 | 01:51 PM
riceburner700's Avatar
valve broke off and it looks like a rod let loose
Old Dec 22, 2008 | 02:30 PM
Sounds about right, i just wanted to rule out any possiblity of this being 'tune' related. Thoughts?
Old Dec 22, 2008 | 02:41 PM
AllMotorRandy's Avatar
It looks as though your motor may have blown .....
Old Dec 22, 2008 | 03:07 PM
Maybe..... LOL
Old Dec 22, 2008 | 03:28 PM
Maybe..... LOL
yeah maybe... throw the head back on and don't forget to use some copper spray for the head gasket...... maybe you'll be able to limp her home......
Old Dec 22, 2008 | 03:29 PM
gstrudler's Avatar
if i'm looking at the pics right, it looks like the pic of the head is cyl 3,2,1 and the block is 4,3,2 to clarify for anyone looking at the pics. as riceburner mentioned, looks like you dropped at least one valve and shattered the piston? not sure how you got so much debris in the other cylinders though.
if i had to take a stab since you were wondering if this was tune related, i would say the rev limit was raised, the motor was pushed on a stock valvetrain and you floated a valve. the valve head snapped off, launched itself at the piston, and voila, toasted motor. just a guess, though.
Old Dec 22, 2008 | 03:35 PM
gstrudler's Avatar
just looking at the pics again though, and they look like aftermarket valves (flat faced and coated). perhaps oversized valves where the bowl was not cut large enough (or at all) and the valves were undercut, reducing their strength. stiff valvetrain slapping the valve against the head (if they weren't seated properly) eventually leading to failure. just another guess. i'm sure there are much more experienced engine builders out there that will know more definitively.
a tuning problem is still a possibility if there was detonation in the motor and that broke the valve loose.
Old Dec 22, 2008 | 03:43 PM
havok hybrid's Avatar
Valve drop at 10K or higher... Thats what happens.. been there done that.. !
Piston is what you see everywhere.. the valve is most likely in only 2 pieces .
Old Dec 22, 2008 | 03:48 PM
Not my engine, I dont know if the valves are stock or not, valvetrain is ITR, rev limit is 8400rpm.
Stock B16 with ITR cams, springs, rets. AFR tuned to 12.9:1 - 13:1( rally car ) 29* timing from 4000rpm onwards low/hi. No sign of det when dyno tuning using Phormula knock detection and det cans, tuned to MBT. Plugs look good and no signs of det on piston tops.
Old Dec 26, 2008 | 12:17 PM
gstrudler's Avatar
what were the conditions when this happened? it's possible the driver missed a shift and over-revved causing valve float.
Old Dec 26, 2008 | 06:19 PM
LowBudgetBEe's Avatar
Dropped valve buddy ive had many. Possibly u needed a vavle adjustment or they were just old valves
Old Dec 26, 2008 | 06:46 PM
b20vtek's Avatar
who ever did that sure knows how to blow a motor
xxstuntin4life
May 1, 2010 12:48 PM
backinblue92
Feb 5, 2010 02:48 PM
RCautoworks
Jun 17, 2008 08:20 PM
JDMKid71
14
Jun 14, 2005 07:15 PM
Specialblend27
Dec 26, 2003 06:31 PM
