What ecu??
Old Jan 24, 2007 | 04:28 PM
jblack34's Avatar
Default What ecu??
I need help with figuring out which ecu to use with a LS/VTEC in a 92 Integra with an automatic tranny. I was told a p28 from a sohc vtec 92-95 Civic EX with an automatic tranny will work. Others say it will not work because it is a sohc and I have a dohc. I don't know what difference it will make as far as how many cams the engine has as far as the ecu is concerned but then again I am fairly new to the vtec power. Please help me if anybody can.
Old Jan 24, 2007 | 04:30 PM
MR_SI's Avatar
Default Re: What ecu?? (jblack34)
um i bet a b16a ecu from one that has an auto tranny. they are over in japan, but try searching for it because i am more then positive that should work. just my .02
Old Jan 25, 2007 | 05:31 PM
jblack34's Avatar
Default Re: What ecu?? (MR_SI)
Thanks! I am also thinking about using a reprogrammed pr4 ecu for the car as is(non-vtec) and use a MSD RPM Activation Switch to activate vtec. I could dial in what rpm is best with the rpm modules(pills). If finding an ecu for what I am doing is difficult to find, is this a possibility?
axis11
Dec 17, 2019 02:17 AM
auto moto
Aug 10, 2004 12:30 PM
tiresmoke
Feb 24, 2004 04:20 AM
celcior
Jun 18, 2003 01:21 PM
tr4il
Nov 25, 2001 11:38 AM
