Help!! Major OIL leak!!!
Old Jan 25, 2007 | 04:37 PM
cbabyby's Avatar
Default Help!! Major OIL leak!!!
i just put my head back on it has been to machine shop....i started my car for a whol 30secs...make sure it was running right.....then finish putting it back together and then start it up to check for leaks....after about 45secs i hear a weird noise... i look under the car and it is pouring oil out like crazy....turn the car off immediately...i cant seem to find where it is coming from it is from about the oil filter all the way to the vtec solenoid.....i think i have got all of the hoses hooked up but behind and around the intake is hard to see....i am fixing my car in the dark...i think it may be the head gasket not sure and sure as hell hope not...i am just making sure that there is nothing else it could be before i rip my car apart again....i think i torqued all the head studs but not sure....i have a 93' civic ex with a jdm b16....and if it is the head gasket is it possible for it to dump out that much oil that fast????
Old Jan 25, 2007 | 05:33 PM
Fezzie's Avatar
Default Re: Help!! Major OIL leak!!! (cbabyby)
its not the head gasket but first check and make sure your head studs are tourqued down, vtec seloniod is tight, oil filter is tight, then your sensors on side of your head. and thats all i got for now
Cameronphelan
Honda Civic (2001 - 2005)
May 29, 2015 10:23 AM
cubanteg16
Oct 2, 2009 01:28 AM
SlammedBlackGSR
Oct 26, 2006 06:56 PM
strsi
Apr 6, 2005 05:28 PM
DsVtec2nrHBC
Dec 2, 2004 04:20 PM
