what does code 92 mean?
Old Aug 21, 2003 | 05:47 PM
96tegsr's Avatar
Default what does code 92 mean?
The question states it.
Old Aug 21, 2003 | 08:08 PM
PHiZ's Avatar
Default Re: what does code 92 mean? (96tegsr)
lack of boobies in the car. go pick up some hot chicks.
-PHiZ
Old Aug 21, 2003 | 08:12 PM
96tegsr's Avatar
Default Re: what does code 92 mean? (PHiZ)
hahah anyone else? i need to know cause i dont quite understand the code..
Old Aug 21, 2003 | 09:07 PM
PHiZ's Avatar
Do you want to know verbosely what the code means? Or what does what causes it.
92 Evaporative Emission Control System
http://www.londonautoclub.org/...s.htm
-PHiZ
Old Aug 22, 2003 | 12:28 AM
96tegsr's Avatar
as much info i can.. because i do not simply know why this code keeps popping up...
Old Aug 22, 2003 | 07:31 AM
JimBlake's Avatar
'96 is OBD2, right?
So the EVAP system probably consists of several solenoid valves, a charcoal canister, lots of vacuum hoses, and a pressure sensor on the gas tank. Something's broken.
The code (92) says which system isn't working (EVAP). You still have to check all the components out. It might be a $40 valve you have to replace, or maybe it's just a vacuum hose that came loose. Your Helm shop manual will have all the details... See if you can find one at a library?
Old Aug 22, 2003 | 08:37 AM
sackdz's Avatar
Default Re: what does code 92 mean? (JimBlake)
Do you tighten your gas cap several clicks?
sanjiyan69
Feb 19, 2007 04:11 PM
DMax013
May 14, 2005 02:07 PM
96tegsr
Aug 14, 2003 12:32 AM
speedymon
Jul 16, 2002 08:39 PM
BlwnBlue
Jul 5, 2001 04:13 PM
