Swapping?
Old Dec 24, 2005 | 11:14 AM
ace0fspades's Avatar
Default Swapping?
What are my options for engines that will fit my car that have more then 150HP? I have a 2002 Civic LX. It has a D series engine in it stock I believe, and it's only pushing about 115HP.
Old Dec 31, 2005 | 05:15 PM
Default Re: Swapping? (ace0fspades)
*bump* any help would be great
Old Jan 2, 2006 | 09:04 AM
shamoo's Avatar
Will you make something up for me please?
Your question is VERY general. Do you have a budget in mind? With an unlimited budget, you can do anything.
Take a look at the FAQ's for engine swaps and see what is good for you. The possibilites are pretty much limitless.
Old Jan 2, 2006 | 02:47 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Swapping? (shamoo)
General question, general answer:
K-Series...
Old Jan 3, 2006 | 04:45 AM
everlasting1832's Avatar
Default Re: Swapping? (JDM_Ej)
do the kseries reqire any cutting of the stock chassis mounts? and does it use special mounts for that as well. what about wiring?
Old Jan 3, 2006 | 06:40 AM
okay to make it a little more specific I would like an engine that will sit on top of the stock tranny.
Old Jan 4, 2006 | 07:15 AM
nobunaga oda's Avatar
i kno what u mean i have a 2000 civic lx manual with a stock d16y7 im looking into swaping it with my friends 2002 civic ex because his is vtec but also automatic so its hard for the car to even reach Vtec
you might want to try a really good site i found called http://www.jspecautosports.com for a JDM engine swap and usualy come in a package with transmisions and stuff
Old Jan 7, 2006 | 06:47 PM
Default Re: Swapping? (nobunaga oda)
Awesome thanks alot
Old Jan 8, 2006 | 08:46 AM
blingking1904's Avatar
do you know anything about doing a b18 swap to a 94' civic lx 4door from a d15 ?
Old Jan 8, 2006 | 08:50 AM
do you know anything about doing a b18 swap in a 94' civic lx 4door from a d15 ?
Old Jan 9, 2006 | 11:33 PM
TEST ONLY's Avatar
Try a turbo H23...
Old Jan 10, 2006 | 08:54 AM
phateless's Avatar
civics and integras/rsx are based on the same chassis. so a k should bolt right into your 02 civic without problems. you'll need the matching tranny tho. and same thing for the 94 civic, a b series should bolt right in, but again, you'll need the matching tranny. try a search, or use the faqs. these questions have been answered LITERALLY 100 times at least...
Jeremy Brewer
Honda Civic (2001 - 2005)
Jan 16, 2013 06:22 PM
Jimbo B
Jun 24, 2011 07:19 AM
Freeltec
Dec 11, 2007 05:53 PM
turbotime
10
Sep 26, 2005 11:21 PM
tonyadams
Dec 18, 2002 07:55 AM
