What is the difference in B16A1 and B16A2 cams?
Old Apr 29, 2007 | 01:14 PM
Wafler's Avatar
Default What is the difference in B16A1 and B16A2 cams?
Cams from the early B16A (or A1 as it is called here in Europe) and cams from the B16A2 are different, at least in appearance.
Link: https://honda-tech.com/zerothread?id=1220642
However, does anybody know if there is a difference in performance? The reason I am asking is that I have a 91' CRX VT (came with B16A1 from Honda) with the early version of the cams (obviously) and I have a set of A2 ones lying around and I wonder if the work is worthwhile to change them.
I know that the displacement , compression and bore/stroke are the same for both motors. The A1 is rated at 150hp and the A2 at 160 - are the cams the determining factor for that difference?
Old Apr 29, 2007 | 01:38 PM
NJIN BUILDR's Avatar
Default Re: What is the difference in B16A1 and B16A2 cams? (Wafler)
I believe the hp difference is in the fuel/ignition maps in the ecu.If the cams are not in the engine than I would use the A2,but if you need to remove them than I wouldn't .
panda_eh2
Apr 18, 2008 12:17 PM
TYPErCRX
Nov 8, 2005 07:58 AM
decapitate85
Feb 1, 2005 01:23 PM
tunes12
Oct 17, 2002 08:02 PM
