What are the chances?
Old Oct 21, 2004 | 06:02 PM
tilt.'s Avatar
Default What are the chances?
ok, so ive been rebuilding my gsr motor for the past few weeks, (its taken so long because im on campus, and my motor is at home) and i just finished putting on the head a few days ago when i realized i never checked the piston ring clearance...i used o/s itr pistons with the oem o/s rings...dumb question, but, do i tear it all back down again and check the clearance, or is there a possibility that they will be fine?
Old Oct 21, 2004 | 06:21 PM
Fobtions's Avatar
Default Re: What are the chances? (dr_jdm)
ive gotten away with not checkin on my motor.
same setup as you. still runnin with no smoke for 2.5 years.
oem parts
Old Oct 21, 2004 | 09:36 PM
ekgcool's Avatar
You could get away with it, but then again it stilla gamble. Think of it this way...spend another 50 bucks on a head gasket, or drop the motor in run it for a few weeks and end up with broken rings, or smoke like crazy. If you hardly have any time to do it right the 1st time, what makes you think you will have time to do it again?
Old Oct 21, 2004 | 09:53 PM
PrettyLude's Avatar
it would be easy to do it since the motor is out
Old Nov 2, 2004 | 08:02 AM
MrIllegalX's Avatar
sell your honda and get a 240. <3 u ryan
kidding. check those bitches. if you don't have time to do it right the first time, when will you have time to do it over?
Old Nov 2, 2004 | 09:56 AM
BigBooster's Avatar
Default Re: (MrIllegalX)
check them. it'll only take you a weekend.
Integra2316
16
Dec 18, 2011 10:44 AM
tempsohc
May 24, 2006 08:11 PM
dirtySOHC's
Aug 23, 2005 06:30 PM
Honda Kustums
14
Aug 27, 2003 07:33 AM
jansenrw
Jun 22, 2003 04:40 AM
