What causes torque steer?
Old Aug 2, 2002 | 03:58 AM
Civic1992DX's Avatar
Default What causes torque steer?
Peeps,
my EG with B18B1 has mad torque steer: when I drive on the hwy & d-shift from 5th to 3rd the car pulls to the left. When I'm upshifting the car momentarily pulls to the right & when I step on it again, it pulls to the left. When cruising & letting go off the steering wheel the car slightly pulls to the left, very slightly... Is that what's causing that bad torque steer? Can rear wheels alighnment cause the torque steer?
Thanx for any input!
Yuri
Old Aug 2, 2002 | 05:15 AM
Default Re: What causes torque steer? (Civic1992DX)
Anyone with suggestion?
Hmmm....
Old Aug 2, 2002 | 07:09 AM
Pants's Avatar
It sounds like you might need an alignment. Get that done and see if it doesn't fix your problem.
Torque steer can be caused by many different things, but it is usually caused by unequal length half-shafts. Switching your soft OEM control arm bushings to firmer bushings can help reduce torque steer, but it won't eliminate it entirely.
Here is a good article on FWD chassis dynamics that has a small explanation of torque steer. http://www.babcox.com/editorial/ic/ic20236.htm
[Modified by Pants, 4:12 PM 8/2/2002]
Old Aug 2, 2002 | 07:14 AM
Default Re: What causes torque steer? (Pants)
all rubber bushings on my car are long gone. Alignment, huh? That's what I thought...
Thanx.
Yuri
Old Aug 2, 2002 | 04:59 PM
mugenracer's Avatar
It could also be either a worn engine mount or worn wishbone bushings, this happened on my civic beater, it would pull to the right on acceleration and then drift to the left on lift off, i brought it to a shop and they swore it was a worn engine mount, but they were all fine so they check the suspension and the drivers side inner wishbone bushing was toast, so replaced it and the car drives perfectly
Old Aug 2, 2002 | 08:27 PM
Default Re: What causes torque steer? (mugenracer)
can't be in my case: I have pretty new poly bushings everywhere but on the rear compensator arms (on the left rear compensator arm i CAN NOT remove the bolt). Engine sits on 2 poly bushings: A/C side & front tranny...
Makes me believe that my rear susp. alignment is off BADLY... Gotta rip that compensator arm off & replace it with new bushings + weld back on the nut pocket...
Thanx for the help, fellows...
Yuri K
[Modified by Civic1992DX, 5:28 AM 8/3/2002]
smxcan
Jan 12, 2009 07:17 PM
mrdeadman
Jul 27, 2005 08:52 AM
TerribleOne
May 15, 2003 06:00 PM
