what can i do to stiffen my engine..?
Old Nov 14, 2004 | 10:10 PM
fastest's Avatar
Default what can i do to stiffen my engine..?
ok i custmized everything on my crx h22a...used prelude mounts..is there anywaz i could get inserts or anything i could by that could make it more stiff so that it doesnt shake....b/c when i get out of clutch in first it shakes:s ...so just wondering if any ideas thanks?
Old Nov 15, 2004 | 05:58 AM
snatch's Avatar
Default Re: what can i do to stiffen my engine..? (fastest)
You can buy Energy Suspension Motor mount inserts or the full mount. I also saw someone make their own solid mounts, but I can't remember where on here I saw it.
Old Nov 15, 2004 | 06:28 AM
tgreaves's Avatar
Default Re: what can i do to stiffen my engine..? (******)
I made my own.. You can use polyeurthane sealant to make them.. It takes about a week to dry though..
Old Nov 15, 2004 | 08:14 AM
snatch's Avatar
Default Re: what can i do to stiffen my engine..? (tgreaves W)
See, I knew someone had done their own mounts.
Old Nov 15, 2004 | 08:22 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">See, I knew someone had done their own mounts. </TD></TR></TABLE>
Yep.. Just use a jigsaw to cut alot of the rubber out of the mounts but leave enough in there to keep the center of the mount where it should be.. Then just fill up the mount with the poly. sealant and smooth it out after your done.. Allow like a week to harden.. You might need to grind down any that sticks out past the center of the mount after its dry.. Dont forget to wear gloves while doing this since this stuff is impossible to get off your hands..
Old Nov 15, 2004 | 08:37 AM
muskrat hatch's Avatar
i remember seeing homemadeturbo (i think) gluing the energy inserts in to stiffen it up even more.
also, i have the energy suspension mount inserts. i like them, but sometimes i regret getting them cause everything rattles all the time.
Old Nov 15, 2004 | 09:15 AM
maxspeedhonda's Avatar
Default Re: what can i do to stiffen my engine..? (chatch152)
I made my own mounts although it might be a little to extreme for your application b/c it will vibrate like crazy. I shaved the rubber off the sides of the mounts first. Then picked up some scrap metal and used a torch to cut them in the same shape of the mounts. The we welded them onto either side of the exsisting mount, therefore creating a true solid mount. However it will rattle the teeth out of your mouth.
Old Nov 15, 2004 | 09:29 AM
mmuller's Avatar
Mad Scientist
Default Re: what can i do to stiffen my engine..? (maxspeedhonda)
i used 3m window weld to fill mine up, it works great
Old Nov 15, 2004 | 09:42 AM
tgreaves's Avatar
Default Re: what can i do to stiffen my engine..? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">i used 3m window weld to fill mine up, it works great </TD></TR></TABLE>
3M Window weld works great also.. I have made a few mounts out of this..
Poroshok
Jul 16, 2007 07:12 PM
ilovejdmhoes23
Jan 18, 2007 04:32 PM
DarKAvEnGeRz
Jun 7, 2005 06:44 PM
ComputerJLT
Jul 2, 2004 02:25 PM
superturboprelude
Dec 15, 2003 09:09 PM
