What Blew? pics inside
Old Feb 13, 2003 | 10:52 AM
Wong Wonder's Avatar
Default What Blew? pics inside
Car is blowing smoke badly and there is a clicking noise coming from the engine bay. New gasket or new engine?
Old Feb 13, 2003 | 10:56 AM
breakneckvtec's Avatar
Default Re: What Blew? pics inside (Wong Wonder)
I dont know your setup or anything so I will take a guess. Maybe you got some piston to valve contact and chipped a valve? Take a dollar bill and put it to your exhaust if it gives any tug in then its a chipped valve. Thats all I can think of from the info you gave. Seems to definetely be the head though.
Old Feb 13, 2003 | 10:59 AM
Default Re: What Blew? pics inside (breakneckvtec)
check my signature
Old Feb 13, 2003 | 11:45 AM
notes
-have been burning small amounts of coolant for awhile
-checked oil cap, no creamy residue
-felt like it lost compression and power
-clicking sound when driven
-horrible idle,sounds like the engine is dying
-started her up again,its leaking coolant badly where the head meets the block on the driver side
Old Feb 13, 2003 | 11:53 AM
Finest's Avatar
Blown headgasket.
Old Feb 13, 2003 | 12:01 PM
Default Re: What Blew? pics inside (98CTRCoupe)
could it be worse? does a blown headgasket do all the other things I mentioned?
Old Feb 13, 2003 | 12:08 PM
kyle h.'s Avatar
sounds/looks like a blown head gasket. as for the clicking, it could be many things. pull the head since u cant drive it and u will know.
Old Feb 13, 2003 | 12:13 PM
Blaze45's Avatar
Brrraaaap!
You blew your headgasket. What causes this to happen?
Blaze
Old Feb 13, 2003 | 12:53 PM
Default Re: What Blew? pics inside (Blaze45)
Yes, how did you blow your headgasket?
Old Feb 13, 2003 | 01:54 PM
bartek_b's Avatar
like the others said, seems like a blown head gasket.
about the clicking noise, my friend had this happen to his DA and he spun a bearing on the crank.
Old Feb 13, 2003 | 01:57 PM
Nameless RB26's Avatar
Default Re: What Blew? pics inside (mugen85r)
Could be a blown head gasket.. more than likely.
DONT run the engine anymore or you'll keep ******* things up. Your valves will not like you for that.
Old Feb 13, 2003 | 02:43 PM
Patch's Avatar
Default Re: What Blew? pics inside (Nameless)
Definately a blown head gasket. I agree that the clicking might be a spun bearing, which you could have done if you got some antifreeze in your oil or ran it very low on oil.
Old Feb 13, 2003 | 07:29 PM
slvrcivic97's Avatar
Default Re: What Blew? pics inside (CRX PAT)
Clicking, blow head gasket.
Old Feb 13, 2003 | 07:52 PM
McFly's Avatar
Default Re: What Blew? pics inside (slvrcivic97)
If it got hot, be sure to check the head for warpage before you put it back on.
Old Feb 13, 2003 | 07:53 PM
Dr_EluSivE's Avatar
looks like a head gasket to me, could have been caused by overheating, Lean burn, too much boost (in turbo apps) or a warped head/block. Just throw a new one on. Its a pain but not a hard fix.
Dr.
Old Feb 13, 2003 | 11:28 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: What Blew? pics inside (Dr_EluSivE)
or you could have overheated and lost viscosity in your oil and thats what cause the bearing to spin, if that even happened.
Deffinately head gasket though
Old Feb 14, 2003 | 06:12 AM
drvfast's Avatar
the clicking noise is it a loud clicking? if so u spun a rod bearing and like everyone else said your head gasket is blown
Old Feb 14, 2003 | 11:10 AM
Default Re: What Blew? pics inside (drvfast)
i now believe that i should have warmed up my car first considering it was -20 celsius, it could also be stripped head bolts
i'll keep this updated
Old Feb 14, 2003 | 06:16 PM
HEAD's Avatar
you will hear a clicking when you blow a head gasket, I have to say one thing quicky and that is a blown head gasket has nothing to do with a spun bearing. what could have happened is when and if you blew the head gasket the water or anti-freeze mixed with the oil, you will see what looks like milk shake (chocolate of course) on the dipstick this is bad for your bearings because if you kept driving it that thin layer of oil that was in between the bearing surfaces and the crank is no longer there and of course this will eat away at the bearings causing excessive bearing clearance and then there will be a knocking sound coming from under the hood! possible symptoms of blown head gasket -car will overheat, have loss of power, and smoke out the tailpipe, or check the oil see if it's milk shaked
Old Feb 14, 2003 | 08:49 PM
Chiovnidca's Avatar
Why would you think the head bolts are stripped? That's not a very common problem.
Old Feb 14, 2003 | 09:04 PM
earl's Avatar
Default Re: What Blew? pics inside (Chiovnidca)
Well I have a different opinion than everyone else. I would look toward a broken piston skirt. With a broken skirt, the piston will rock in the bore. When it hits top dead center, the rocking will actually allow the piston to slap the cylinder head in one corner. There seems to be little oil control available and causing large amounts of blow by causing the smoke and oil.
The noise you get is kind of ticking noise like a valve out of adjustment.
garyguo4
Jan 29, 2019 05:10 PM
markers.
Feb 6, 2010 04:54 PM
es_squared
Dec 11, 2007 06:02 AM
ylfotevoli
Apr 30, 2007 07:00 PM
Loveless
Mar 24, 2003 12:54 AM
