what is B18 and B20 diffrences?
Old Jun 25, 2009 | 11:20 AM
hondajav06's Avatar
Default what is B18 and B20 diffrences?
can any one tell me what is the diffrences between a b18 and a b20? I am trying to swap my b20 in my crv for a b18
Old Jun 25, 2009 | 11:12 PM
angel_i's Avatar
Default Re: what is B18 and B20 diffrences?
I think they are different in the intake manifold and the B20 has a bigger bore. The Jdm P8R has a better flowing head also.There are more differences 2.
Old Jun 26, 2009 | 09:38 AM
Spoon84's Avatar
Different Intake manifold. You'll need to your LS intake manifold. The head is somewhat the same... but some say it flows better. Also the block is 84mm compared to 81mm LS. The compression is pretty much the same. The factory B20 Oil pump produces more better oil pressure than say a 95 and below LS motor. That pretty much it.
But the block swap is diffenelty worth it. More low end torque. If you decided to put a vtec on it later on. The b20/vtec motor with high compression pistons and depending on other stuff you upgrade could yield between 200+230 hp.
Old Jun 26, 2009 | 10:10 AM
kyden's Avatar
which b18?
immrtaltchnq
Oct 21, 2008 07:46 AM
tpb18b1
Jul 1, 2005 07:55 PM
ALLMOTA92EG
Feb 6, 2005 11:28 PM
who00knows
Feb 20, 2003 02:18 PM
civicdragger818
Feb 17, 2003 06:53 PM
