what am I missing from a full longblock
Old Oct 7, 2003 | 11:33 PM
wm5holla's Avatar
Default what am I missing from a full longblock
i still trying to piece my motor 2gether. tell if i am 4getting anything
-block w/pistons,cranks,rods,oil pump
-water pump
-oil pump
-full head w/ T-belt
-alnt
what am i missing?
Old Oct 8, 2003 | 04:06 AM
Atheist's Avatar
do you have a dizzy and all of that stuff?
Old Oct 8, 2003 | 07:04 AM
wm5holla's Avatar
Default Re: (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">do you have a dizzy and all of that stuff?</TD></TR></TABLE> that all will be on my FULL head
Old Oct 8, 2003 | 07:41 AM
poison's Avatar
Default Re: what am I missing from a full longblock (wm5holla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">i still trying to piece my motor 2gether. tell if i am 4getting anything
-water pump
-oil pump
-alnt
what am i missing?</TD></TR></TABLE>
tensioner, dizzy, oil pick up, oil pan..
Old Oct 8, 2003 | 08:23 AM
wm5holla's Avatar
Default Re: what am I missing from a full longblock (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
tensioner, oil pick up, ..</TD></TR></TABLE> what is the oil pick up?
Old Oct 8, 2003 | 08:29 AM
1_bad_EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote"> what is the oil pick up?</TD></TR></TABLE>
if the engine has a oil pan on it, you prolly have the oil pickup.
it is only visible when you remove the oilpan.
Old Oct 8, 2003 | 08:39 AM
BeerMan's Avatar
Default Re: what am I missing from a full longblock (1_bad_EF)
what about the crank pulley and timing belt cover?
Old Oct 8, 2003 | 08:41 AM
wm5holla's Avatar
COOL
Old Oct 8, 2003 | 08:42 AM
wm5holla's Avatar
Default Re: what am I missing from a full longblock (BeerMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerMan &raquo;</TD></TR><TR><TD CLASS="quote">what about the crank pulley and timing belt cover?</TD></TR></TABLE> T-BELT COVER? do u need this?
Old Oct 8, 2003 | 09:14 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote"> T-BELT COVER? do u need this?</TD></TR></TABLE>
I would rcommend having it..
keeps debris out of the water pump area.
Old Oct 8, 2003 | 10:37 AM
BeerMan's Avatar
What about the crank gear AKA timing belt gear
Old Oct 8, 2003 | 10:51 AM
noble4ws's Avatar
i would recommend having the timing belt cover i am putting together an h22 and put the crank pulley on without the timing belt cover and when i was torquing it down the crank pulley pushed into the oil pump drive pulley and cracked it real good the timing belt cover prevents that from happening
Old Oct 8, 2003 | 11:11 AM
Kamin's Avatar
http://www.helminc.com
go buy a helms.
Old Oct 8, 2003 | 11:38 AM
wm5holla's Avatar
Default Re: what am I missing from a full longblock (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">http://www.helminc.com
go buy a helms.</TD></TR></TABLE> trust me i will, so i can stop askin dumb ****! but brand should i buy, arent there 3 kinds , chilton,hemls andi forget the name
Old Oct 8, 2003 | 11:57 AM
Kamin's Avatar
once again
buy a HELMS
Old Oct 8, 2003 | 12:04 PM
BeerMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">once again
buy a HELMS
http://www.helminc.com</TD></TR></TABLE>
You might think the helms is expensive, but it is 100% worth it. I remember the first time I cracked open my helms, it was like the first time I looked at a **** mag.
Old Oct 8, 2003 | 12:06 PM
wm5holla's Avatar
what hemls should i buy, my block is a 91 b18a but i will converying it to a 92-95 b18b with b18b parts so i buy..........
Old Oct 8, 2003 | 12:19 PM
wm5holla's Avatar
im on the helms site lookin for a fcukin 91 teg book
Old Oct 8, 2003 | 02:06 PM
owen_the_soyboy's Avatar
get the one for a 94+ Integra.
it will cover the OBD1 GSR and LS motors and have similarities to your 92-95 OBD1 Civic.
it is what I have and it has helped me do everything I have done... which is rebuilding the entire motor, suspension and doing the "scary-oh-my-god-there-are-too-many-parts-in-here" tranny work as well.
wm5holla, you're funny with your basic questions all the time, I cant wait for you to FINISH your setup and enjoy it!
mouab18c1
Oct 21, 2008 07:02 AM
k24killer
May 23, 2007 08:14 AM
cvp467
Nov 25, 2006 01:51 PM
phyzJunkieCivic
Nov 7, 2006 01:09 PM
vtec-gorilla
Sep 1, 2006 09:05 PM
