???????????welding your differentials??????????
Old Apr 18, 2004 | 07:56 PM
kcalb_3pe's Avatar
Default ???????????welding your differentials??????????
just wondering what do you get out of welding your stock diffs....
Modified by 92whitecx at 5:11 AM 4/19/2004
Old Apr 18, 2004 | 08:29 PM
Kamin's Avatar
Default Re: ???????????welding your differentials?????????? (92whitecx)
positives: no more 1 tire fire, meaning both wheels get power. thats the ONLY ADVANTAGE
disadvantages: turning problems, tire wear problems, if you like to go fast and turn, its not a good combonation.
why is it bad? because on a turn, the outside wheel has to travel farther than the inside wheel, if the differental is welded it physically cant so it skips or hops making a chirping sound in turns.
welded difs are for drag racing ONLY IMO.
Old Apr 18, 2004 | 08:39 PM
Lsos's Avatar
Yeah, they're only good if you go in a straight line, or possibly on snow or gravel or something like that, in that they always distribute power to both wheels evenly. Otherwise, if you ever want to turn on pavement you'll get many more problems than you solve.
Old Apr 18, 2004 | 09:26 PM
func-tion's Avatar
Default Re: ???????????welding your differentials?????????? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
welded diffs are for drag racing ONLY IMO.</TD></TR></TABLE>
or tractor pulls hehe
There are a few companies out there that make spools which achieve the same thing.
This is the first one I found on google.
Old Apr 19, 2004 | 09:26 AM
kcalb_3pe's Avatar
so its like having lsd right???
Old Apr 19, 2004 | 09:40 AM
Kamin's Avatar
NO it is NOT. it is a locked differental. a LSD allows normal turning and locks under force.
Old Apr 19, 2004 | 09:50 AM
skunked's Avatar
And a welded diff can blow up. Get a spool if you want to do it right.
Old Apr 19, 2004 | 01:01 PM
kcalb_3pe's Avatar
Default Re: ???????????welding your differentials?????????? (skunked)
what does this spool thingy do...
Old Apr 19, 2004 | 01:48 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92whitecx &raquo;</TD></TR><TR><TD CLASS="quote">what does this spool thingy do...</TD></TR></TABLE>
same thing a welded diff does, but safer and lighter.
Old Apr 19, 2004 | 02:25 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
same thing a welded diff does, but safer and lighter.</TD></TR></TABLE>
And still not for a street car.
Old Apr 19, 2004 | 05:50 PM
kcalb_3pe's Avatar
Default Re: ???????????welding your differentials?????????? (Chiovnidca)
thanks everyone this is very informative.....
Old Apr 20, 2004 | 07:24 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
And still not for a street car. </TD></TR></TABLE>
That depends if you want to drive your "street car" on the streets
Old Apr 20, 2004 | 11:17 AM
rapid_roy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">welded difs are for drag racing ONLY IMO.</TD></TR></TABLE>
There was a guy whose name escapes me at the moment who won the SCCA nationals in his CRX with a welded diff.
I also think the current issue of Grassroots Motorsports has an article on this, might be worth checking out.
Old Apr 20, 2004 | 11:27 AM
Kamin's Avatar
Default Re: ???????????welding your differentials?????????? (rapid_roy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy &raquo;</TD></TR><TR><TD CLASS="quote">There was a guy whose name escapes me at the moment who won the SCCA nationals in his CRX with a welded diff.
I also think the current issue of Grassroots Motorsports has an article on this, might be worth checking out.</TD></TR></TABLE>
yea its still 99% driver, just because it can be done dosent mean its smart.
laws of physics man, the outside tire MUST travel farther, since it cant, something MUST give. usually its the tire. sometimes its an axle, sometimes its the diff.
Old Apr 20, 2004 | 11:53 AM
Lord Helmet's Avatar
also it's illegal to run a welded diff at any NHRA track.
it has to be a LSD or locking diff only.
jshi182
Sep 30, 2008 03:01 PM
TurbodTegSfaria
Jan 2, 2007 09:22 PM
BoostR41
May 16, 2006 08:12 PM
AllMoToRB18c
Aug 25, 2005 02:44 PM
AllMotorRandy
Jul 6, 2004 10:01 AM
