Weird Tranny Problem?
Old Dec 7, 2006 | 08:47 PM
my_civic's Avatar
Default Weird Tranny Problem?
A while ago I had a transmission problem: The car won't shift into any gears when the car is started (it's simply stuck in neutral, not grinding) and if I start the car in first gear, it would do a few hops foward while it cranks (even with the clutch down), and once I get the car going in first gear, I won't be able to shift out of any gears.
Well to make the long story short, I replaced the tranny (left the clutch and pressure plate), and I tried starting the car while it was on jack stands. This time, I can shift into gears without even pressing down on the clutch! But when in gear, I can see the wheels spin. Can't shift into reverse at all, and if I step on the brakes, I can't shift into any gears again.
So guys, is it my clutch, is it my pressure plate, or is it still the tranny?
cordino
Dec 25, 2008 07:17 PM
EJK20R
May 30, 2006 09:45 AM
RenoRacing
Feb 3, 2003 11:38 PM
lukedogg49525
Jul 30, 2002 01:16 PM
