Weird Idle and Stalling? Please help!
Old Jan 25, 2002 | 12:53 AM
LshatchTurbo's Avatar
New User
Default Weird Idle and Stalling? Please help!
Heres the story. I have a 92 Hatch DX. Before i did the engine swap, sometimes, mostly on a hot day, i start the car, it idle then it stall out. I figure I just hold off until i can get my engine swap. So, now i have my new engine in. Its a OBD1 B18b1. Now the idle fluctuates, even when I have adjusted it. And on hot days, it always stalls out. When I turn the car on it idles high for about 5 secs, this is from stop and go traffic, then drops a good 400 rpms. The stalling part is what is confusing me the most. It is exactly what the car was doing when I had my Stock DX engine in. I have replaced, spark plugs, wires, distributor car and rotor, O2 sensor, Fuel Filter, Fuel Pump, ran some fuel system cleaning in for the hell of it. I would like to know everyones opinion on the situation here. Could it be a coolent system problem that is causing the stalls? More sensors? BTW, fuel pressure never drops, and there are no codes throwing. Any ideas?
Old Jan 25, 2002 | 07:22 AM
Urban Business
Guest
Posts: n/a
Default Re: Weird Idle and Stalling? Please help! (Zynentech)
you check your thurmostat?
Old Jan 25, 2002 | 02:46 PM
bob01721's Avatar
Are you using the original alternator?
Sometimes a bad alternator can cause an rpm drop and/or stalling. Honda uses what it calls an "FR" signal from the alternator to the ECU. If this signal is missing or screwy, the car will drop rpm's and/or stall on decel or at idle.
GT500FTW
Oct 5, 2012 02:26 PM
delslow302
Mar 22, 2009 03:49 PM
johnjohn072002
Jun 7, 2007 01:04 PM
Andrew 825SM
Oct 20, 2004 09:52 PM
LshatchTurbo
Jan 29, 2002 07:21 PM
